Forum Home Forum Home > General Discussion > How-To Articles
  New Posts New Posts RSS Feed - 65 Mustang Floor Pans WORK
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 3:22PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 3:29PM
The under rear seat panels are available for sale seperately.
To see the right side for sale Click here.
To see the left side for sale Click here.
Edited by dave302 - 02-November-2015 at 3:30PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2016 at 4:58PM
He was never going to use the original type of seats, seat brackets or cross brackets/braces from the beginning. He was not concerned with the stock seat mounts with the custom seats and mounts he is going to use. He laid the seat bracket back on to see how it fit after his weld in. The stock bracket is raised up over an inch the way he welded it in.
But, he did some looking and it appears that if you left the bracket/brace in place, cut the rotted floor board out and then slipped the mustang panel in under the bracket then welded it to the bracket, you should be able to form the panel to meet the existing floor on the sides.
There are pictures below.
Edited by dave302 - 20-February-2016 at 5:10PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2016 at 4:59PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2016 at 5:00PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2016 at 5:02PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2016 at 5:03PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2016 at 5:07PM
russosborne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 13-May-2016 at 7:51PM
I am going to be doing this on my Ranchero thanks to this thread.
I bought my panels from CJ Pony Parts.
http://www.cjponyparts.com/XFLP1L/p/XFLP1L/?utm_source=Pony&utm_medium=Email&utm_campaign=OrderConfirmation&lac_guid=550ffb38-4112-e611-be9f-2c59e547f8d7
I bought the premium since they have a bit more material at the rear. And they are 19 gauge, the other ones didn't have a gauge listed. Might be overkill and most who have experience probably won't need the extra material but I figured I better get as big a piece as possible. Not sure if it was worth the extra $30 or not though. I bought them as a pair, free shipping. Free shipping from them either way you buy.
They also sell the under the seat part mentioned above somewhere, I may try those or just see what I can make with some metal I have. At $30 something each side though I am leaning towards making patches instead.
I am going to be doing it with the seat bracket still on the car. Mine needs repaired on the inner rear seat bolt hole areas, both sides, but I am not a welder and so I want to leave as much structural as I can intact. I can see how that may make part of this harder, but at least I won't have to worry about the bracket being wrong. That part holds the seats and thus the people, so it needs to be solid. I plan on removing the floor pans, fixing the brackets, then doing the new pans. I weigh in at about 305, so I am a bit concerned.
This will be a real learning experience. I've done a very little welding in a one evening class where we had to share the welder.
I will post in my project thread when I start. Going to be a bit, I forgot I am going to need to come up with an extension cord for the welder since my Ranchero is too far from an outlet. I will probably have to make one out of Romex, just don't tell anyone. Tongue
I hadn't planned on needing to use the welder when I took the front end apart. Unhappy
But at  least it is far enough from the house to avoid burning it down. LOL
Thanks,
Russ
Edited by russosborne - 13-May-2016 at 7:54PM
Regul8r 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r 2 Quote  Post ReplyReply Direct Link To This Post Posted: 12-June-2016 at 11:14AM
Some of those are the pics I took when I hung out with Jimmy here locally at his shop.
Those pans fit PERFECT!
IF you want to use the original seats you will have to leave the cross brace in place or at least after you cut out the rust put a tack weld to hold it in place on the tranny tunnel.
from the picture you can see the brace sits higher on the tranny tunnel.
Just means a little less trimming excess off the mustang pan to get it to sit lower like the torino.
Personally I was looking and you could cut the brace then weld it back in. just remember that his seats will sit HIGHER because the floor is higher as seen by the space between the brace and the tunnel.
As for the rear... YES, use the right pan on the left and left pan on the right to fit in our cars with a close contour.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-June-2016 at 11:34AM
yes this is the thread i was referring to! carl, can you throw a sticky on this!!!
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r 2 Quote  Post ReplyReply Direct Link To This Post Posted: 12-June-2016 at 1:13PM
DONE
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-June-2016 at 1:53PM
DONE
Clap good because you know how often this subject comes up, plus it may be easier for new guys to find! Wink
