  New Posts New Posts RSS Feed - 68 torino suicide rear doors need help
cutthroaxxx View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote cutthroaxxx Quote  Post ReplyReply Direct Link To This Post Topic: 68 torino suicide rear doors need help
    Posted: 02-October-2015 at 6:26PM
I Have a buddy wants to do suicide doors on his back once it is a 1968 Torino 4 door the kits to do it are crazy can anybody help me out here?
Edited by cutthroaxxx - 02-October-2015 at 6:26PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-October-2015 at 3:40PM
generally, to suicide the doors, they need to swing out away from the body, i've often thought about using door hinges from like a '56 f100, they swing out away from the body! just an idea...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 10-October-2015 at 4:07AM
Look at the 67-71 4-door t-birds, maybe they can get you pointed in the right direction.
The hinges don't have to be external, but the pivot points (hinge pins) have to be in-line with each other. Because most 4-doors have a curved edge to the read door that follows the wheel arch, the hinges need to be closer together than on a front mounted door. Closer hinges mean that the structure needs to be stronger to support the same load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-October-2015 at 5:38AM
the '56 f100 hinges aren't "external" but good point about the rear doors and the "dog leg" part of the door!
53 54 55 56 Ford Pickup Door Hinge, Fits RH or LH
