68 torino suicide rear doors need help |
cutthroaxxx
Brand New Member Joined: 02-October-2015 Location: United States Status: Offline Points: 1 |
Posted: 02-October-2015 at 6:26PM |
I Have a buddy wants to do suicide doors on his back once it is a 1968 Torino 4 door the kits to do it are crazy can anybody help me out here?
Edited by cutthroaxxx - 02-October-2015 at 6:26PM |
generally, to suicide the doors, they need to swing out away from the body, i've often thought about using door hinges from like a '56 f100, they swing out away from the body! just an idea...
Look at the 67-71 4-door t-birds, maybe they can get you pointed in the right direction.
The hinges don't have to be external, but the pivot points (hinge pins) have to be in-line with each other. Because most 4-doors have a curved edge to the read door that follows the wheel arch, the hinges need to be closer together than on a front mounted door. Closer hinges mean that the structure needs to be stronger to support the same load.
the '56 f100 hinges aren't "external" but good point about the rear doors and the "dog leg" part of the door!
