  New Posts New Posts RSS Feed - 71 torino gt drum to disc
71Torino552 View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote 71Torino552 Quote  Post ReplyReply Direct Link To This Post Topic: 71 torino gt drum to disc
    Posted: 05-June-2017 at 2:43PM
Hello my sons and I are working on a 71 torino project car. We are putting in a 552 with a c6. And upgrading the front brakes. The car has manual drum all four wheels now. When we bought the car it came with the rotors and spindles. We also want to upgrade to vacuum booster. Will this be a direct bolt in or is there work to be done on the firewall to mount the booster. And will the car need a or a new proportion valve. Also looking for a service manual to buy .
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-June-2017 at 3:27PM
yes use the disc/drum prop valve that wound go with that system that the discs came from,and the pedal will need the pin relocated for the booster  as it takes less leverage/effort with the booster, or swap pedals if they fit the same (power brakes will have the pin closer to the pivot Wink)
This page was generated in 0.064 seconds.
