  New Posts New Posts RSS Feed - '71 Torino Tachometer
snakeoilsam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snakeoilsam Quote  Post ReplyReply Direct Link To This Post Topic: '71 Torino Tachometer
    Posted: 15-May-2015 at 5:15AM
Hi. Can anybody tell about adding a factory tach to my '71? I picked up one about 6 years ago and just installed it yesterday. It has continuity across the leads. I just ordered the tach wire / plugs from Dearborn classics. It looks as if it mounts in the firewall? Where?? Will I need anymore wiring or is it just a matter of moving some wires around??? I have the dealer vacuum / wiring book but it does not show the tach wiring. Thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote snakeoilsam Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2015 at 5:00AM
Never mind. I found a hole that I plugged last year and put the loom in it. The ignition wire plug was right next to the hole. Unplugged and re-plugged. Car started and tach works fine. I read several posts about using the tach. One person wrote that having the clock is better. I agree. But I had the tach so I'm going to use it. As far as tachs go, I found a steering column mount, 4k rpm tach with a 3" face about 10 years ago on ebay. I was questioned (ridiculed) about the 4k rpm and told that I should have bought one that was 8k. My answer is this.... A tach that is 8k rpm is not as exact as a 4k rpm tach. Just as the Ford ribbon tach will only give you a ballpark of the rpm, so will a tach that has the lines squeezed in. The 4k rpm tach was put on a '68 GT/CS with a 289 / 2V. I will never rev it over 3500 rpm so why would I need one that goes to 6 or 8k? I use my tachs to keep an eye on idle and cruising rpm. Happy motoring!!
ramair351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ramair351 Quote  Post ReplyReply Direct Link To This Post Posted: 29-May-2015 at 3:55AM
A 4k tach is probably from a boat, I used to have one too, cool looking
-Pete
1972 montego GT
1970 Torino cobra SCJ
1970 mustang mach 1
1965 Falcon futura
threedwizard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote threedwizard Quote  Post ReplyReply Direct Link To This Post Posted: 11-December-2016 at 6:35PM
Was your Torino factory equipped with the tach, or did you just buy a tach and the harness?
Thanks
1971 Torino GT Convertible
