'71 Torino Tachometer |
snakeoilsam
New Member Joined: 15-May-2015 Location: Torrance Ca Status: Offline Points: 5 |
Posted: 15-May-2015 at 5:15AM |
Hi. Can anybody tell about adding a factory tach to my '71? I picked up one about 6 years ago and just installed it yesterday. It has continuity across the leads. I just ordered the tach wire / plugs from Dearborn classics. It looks as if it mounts in the firewall? Where?? Will I need anymore wiring or is it just a matter of moving some wires around??? I have the dealer vacuum / wiring book but it does not show the tach wiring. Thanks!!
snakeoilsam
Never mind. I found a hole that I plugged last year and put the loom in it. The ignition wire plug was right next to the hole. Unplugged and re-plugged. Car started and tach works fine. I read several posts about using the tach. One person wrote that having the clock is better. I agree. But I had the tach so I'm going to use it. As far as tachs go, I found a steering column mount, 4k rpm tach with a 3" face about 10 years ago on ebay. I was questioned (ridiculed) about the 4k rpm and told that I should have bought one that was 8k. My answer is this.... A tach that is 8k rpm is not as exact as a 4k rpm tach. Just as the Ford ribbon tach will only give you a ballpark of the rpm, so will a tach that has the lines squeezed in. The 4k rpm tach was put on a '68 GT/CS with a 289 / 2V. I will never rev it over 3500 rpm so why would I need one that goes to 6 or 8k? I use my tachs to keep an eye on idle and cruising rpm. Happy motoring!!
ramair351
Senior Member Joined: 08-May-2006 Location: west michigan Status: Offline Points: 1561 |
A 4k tach is probably from a boat, I used to have one too, cool looking
-Pete
1972 montego GT 1970 Torino cobra SCJ 1970 mustang mach 1 1965 Falcon futura |
threedwizard
New Member Joined: 30-July-2016 Location: Salt Lake City Status: Offline Points: 7 |
Was your Torino factory equipped with the tach, or did you just buy a tach and the harness?
Thanks |
1971 Torino GT Convertible
Philip
New Member Joined: 19-April-2019 Location: Georgia Status: Offline Points: 13 |
If the car came with one from the factory where would it have been?
mine is a 71 Torino 500 converted to 5spd and no console. did these car come with consoles? thanks
Phil
i believe they were in the lower part of the dash below the speedo???
i believe some were available with a console? |
Philip
I'll see if your friend Troy has something.
thanks again
Phil
The 1970-71 Torino Tach is on the left side of the dash, below the speedometer. It was a ribbon style tachometer. It was a little gimmicky, but kind of cool.
Here is a video of one in action: |
Philip
That is too cooool !!
Thanks
Phil
