  New Posts New Posts RSS Feed - 72 gts 4 speed speedo gear
72gts805 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72gts805 Quote  Post ReplyReply Direct Link To This Post Topic: 72 gts 4 speed speedo gear
    Posted: 05-May-2018 at 7:37PM
Does anyone know where I can find one? 351 4v 4 speed toploader. Having trouble locating one
1972 gts 351cj 4 speed
2001 f250 4x4 4wd 37s
1993 jeep gcl 5.2m 4wd
2000 Nissan frontier daily
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2018 at 8:25PM
Drive (internal) or Driven (External / Cable end)?
91 F-150
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72gts805 Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2018 at 8:47PM
Hey Chuck thanks for the response. To he quite honest I'm not sure what u mean. I know I took off a bracket bolted to the side of the transmission holding the cable to the plastic gear in n the plastic gear was rounded causing the cable to not spin
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2018 at 9:03PM
sounds like he's needing the cable gear, i believe someone said the cable is on the other side of the tail shaft housing (opposite of an auto) do the 4 speed gears have opposite rotation teeth???
how many teeth are on whats left of the gear you have now?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72gts805 Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2018 at 9:06PM
The teeth on the gear are completely fine. It's the inside of the gear where the cable goes into that is rounded instead of squared to make the cable spin. I'm not 100% how many teeth it is now. I put it back on n went by rpm for mph. Thank u also for a response
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2018 at 10:41PM
If I understand correctly, you need the driven gear(inside of gear where cable resides is rounded out). Try National Parts Depot, the manual transmissions use a LH rotation driven gear, whereas an automatic uses a RH rotation gear. A few pages to look at, hopefully find the needed gear tooth count gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-May-2018 at 8:28AM
ok that sounds like an easy fix, before you put the new gear on i'd check your cable, it may be screwed up and caused that to round out???
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72gts805 Quote  Post ReplyReply Direct Link To This Post Posted: 10-May-2018 at 8:47PM
Thank u guys for the responses. I tried NPD n they don't have anything for my application. Summit, jegs, all parts stores included. But I will definitely try the cable inspection also. But the next question would be how can I check if my cable is messed up? Sorry for the late response my phone got broke n barely got a replacement. If anyone wants to contact me directly that would be awesome. grantorino1972351@gmail.com or 8053360178 thanks, Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 11-May-2018 at 1:24AM
If you mentioned the word "Torino" they will just about tell you to get lost, so to speak. Try going in and saying "Ranchero" (I live about 20 miles from NPD-Ocala, Fl), that gets me a cross-eyed/cringed face reply every time. Try here: http://4speedtoploaders.com/store/speedometergears.html
