  New Posts New Posts RSS Feed - 72 GTS Deuce
72 GTS Deuce
 Post Reply Post Reply Page  <1234 48>
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2012 at 11:56AM
Those wheels in those sizes are pretty hard to find. More common was the 14 X 7 and 15 X 7. As a reference, I was asking $200 for the set of 14 X 7 chrome Magnums on my '73, but only had 1 bite. I guess mine will be used on a trailer, spray booth wheels or something around my house.
1972 GTSquire Wagon
foote500 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2012 at 12:18PM
I stopped them in the middle tacking it on, so its not completely attached.
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2012 at 12:40PM
well I see that but why did they cut around the marker light?did the quarter not have that stamped into it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2012 at 1:17PM
i cut around mine too.  even though they are stamped in there.  i will probably go ahead and cut mine out.  my gasket is toast.  can you get any more of those?  or would i have to make one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2012 at 1:24PM
I guess everyone has thier way, I always felt it was unessesary to cut sound metal.
72BoB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72BoB Quote  Post ReplyReply Direct Link To This Post Posted: 25-January-2012 at 9:55AM
Originally posted by ilyes ilyes wrote:
shipping should be $16/wheel with USPS, that what the guy that wants mine told me, he sells wheel on ebay on a regular basis
The Vector wheels you have are aluminum wheels. The Magnum 500's are steel and they weigh a ton...
I have 2 14x6 Magnums that I'm hanging onto if you want to make it a full set of 14x6!
1972 Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 26-January-2012 at 3:18PM
Trunk floor has arrived, will take pictures Friday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2012 at 7:01AM
Trunk floor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 26-February-2012 at 1:47PM
Finally found my Holy Grail-two of them. A spreadbore 4300 and a 30 case of Schaeffer!!
kenneth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenneth Quote  Post ReplyReply Direct Link To This Post Posted: 26-February-2012 at 2:03PM
Going too alcohol injection , I see Smile
4 gallons per hour
1973 Q code sports roof
SocalTorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SocalTorino Quote  Post ReplyReply Direct Link To This Post Posted: 26-February-2012 at 2:57PM
Is the Holy spreadbore 4300 a good carb?
And what cars did they come in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 26-February-2012 at 3:13PM
From what research I have been able to do-the 4300 is a "good" carb. The 4300 D is a better carb (still havent figured out the diff), and the 4350 is a piece... Also, from what I know-and my knowlege may not be complete, the spreadbores started in 1970 or 1971 and went up until the late 70's. You can find alot of 4350's, they mostly came on Lincolns-or at least they seem to be the majority of the ones for sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 12-October-2012 at 9:09AM
Finally some progress!
Marc
German Shepherd Rescue
1972 GTS "The Gray Ghost"
1967 Ford Fairlane 500
kversch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kversch Quote  Post ReplyReply Direct Link To This Post Posted: 12-October-2012 at 9:25AM
is that the trunk floor you got from desert valley?   I would love to see some pics of the removal and install.  i have to do some work on my trunk floor as well.   I have a good doner floor just not sure how exactly i want to go about doing it.   Did you drill out all the spot welds or just cut it out to match?
-kevin-
Brown 72 gran torino 351c 2v
Black 73 GTS FB 302
Red 73 GTS FB 351C C6 trans
73 GTS FB Parted
97 F250 crew cab 7.3 diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 12-October-2012 at 11:12AM
Yes, that is the floor from desert valley-unfortunately the guys at my shop have been sitting on it since feb and put it in like ninjas, I wanted to get in progress photos, but didnt. I think they did drill out the spots welds though.
Marc
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 12-October-2012 at 3:55PM
difference between the 4300 and the 4300d is this.
4300 = squarebore with 605cfm rating
4300D = Spreadbore and 750cfm rating
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 25-January-2013 at 10:57AM
Had my guys pull all the trim off of this, going to send to the guy in the vendor section, will he work on the head light chrome as well, do you think. Plus, I think I am going to do the blue laser strip. And they pulled the dash pad out as well, gonna send that to CA to be redone.
Marc
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 25-January-2013 at 1:41PM
I really like the gold/black contrast
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 25-January-2013 at 2:09PM
Me too.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 28-March-2013 at 8:36AM
Finally some movement. Almost ready for primer.
Marc
