  New Posts New Posts RSS Feed - 72 GTS Deuce
72 GTS Deuce
 Post Reply Post Reply Page  <1 3536373839 48>
foote500 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 15-March-2017 at 12:06PM
Soooo....I took the plunge, he is going to put a cam, lifters and timing assembly in as well, so my mechanic does not have to do too much. Basically it worked out to 1400 bucks. He is going to put a torky cam in it.
Here are a couple of quotes from him"
"Perfect choice for your CLASSIC Gran Torino Sport! The dished forged pistons will deliver 9.5to1 compression ratio, with your 4v heads, perfect for todays unleaded fuel. Recommend a cam with 218-228 degrees duration at .050" on 112`LSA, for best street performance, delivering a loping sound in the exhaust, with enough vacuum to properly operate the power brakes."
"I would use a dual pattern camshaft, with shorter intake duration with wide 114 degree lobe separation angle, creating higher cylinder pressure and TORQUE!!"
Lets us pray...Beer
Marc
German Shepherd Rescue
1972 GTS "The Gray Ghost"
1967 Ford Fairlane 500
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 15-March-2017 at 12:26PM
Ok... So he's going thru the bottom end? Bearings, rings,oil pump....etc?
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 15-March-2017 at 12:31PM
It is already built-brought from e bay. Not having the guy who quoted 5k doing it, getting this instead:
Edited by foote500 - 15-March-2017 at 12:33PM
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 15-March-2017 at 1:05PM
Oh.OK. For a minute I thought you were putting a cam in your old engine with out going thru it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 21-March-2017 at 6:12AM
Engine on its way. :)
Marc
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 21-March-2017 at 9:51AM
I notice it says dished pistons, did you check how many CC the dishes are? If not you may end up with a dog of an engine!
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 21-March-2017 at 8:39PM
The dish has a volume of -10cc, including the valve notches.
Marc
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 22-March-2017 at 2:10AM
You have closed chamber heads to use off your other engine though, right?
Past 1974 Ranchero GT Q code
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 22-March-2017 at 2:49AM
Yes
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 22-March-2017 at 4:23AM
rough guesstimate 9:1 using 66cc chambers, .030" deck clearance and .040" gaskets
change the chambers to 63cc and you make 9.3:1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 22-March-2017 at 8:10AM
That is what i did on one of the 460's and it's a great combo. Good power and pump gas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 22-March-2017 at 9:56AM
His quote:
The dish has a volume of -10cc, including the valve notches. With 62cc heads, the compression ratio is 9.45to1, perfect for today's unleaded fuel!!
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 22-March-2017 at 10:41AM
i'll agree with that within the margin of variables, head gasket thickness, fire ring shape (head gasket volume), deck clearance ... your exact chamber cc volume will obviously have a significant impact on the static CR calculation. my link up above http://www.network54.com/Forum/136503/thread/1329504375/last-1357658605/View+Thread there it is again shows that the early D0xx (1970 model year production) heads have a slightly smaller chamber than the D1xx heads (1971 model year production) and any including your can have been milled some time during the last 47 years give or take. the published data has been known to be a little incorrect also, for instance the Boss 351 did not have the advertised 11.3:1 compression ratio. i forget what we figured it out to be but it was a good full point lower. so anyway for a decent SWAG you'd need to cc the chambers and measure the deck clearance distance at TDC
here's what i mean by gasket bore diameter,
http://www.network54.com/Forum/119419/thread/1333300266/Fel-Pro+Head+gasket+8347PT+1+or+1013+or+---
the blue gasket is Fel-Pro 8347PT-1, standard replacement composition style 'no retorque' and the other is Fel-Pro 1013 performance style with a metal wire inside the fire ring around the chamber
settled on a cam yet? where I'm going is that you want to choose a cam that provides right at / close to / not much over 8:1 Dynamic Compression Ratio for a happy on pump gas / not a dog build
Edited by Rockatansky - 22-March-2017 at 10:42AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 22-March-2017 at 1:53PM
He put in a dual pattern cam.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 23-March-2017 at 12:46PM
Your car should run really well with this new short block.
Do you know the came specs?
Did you have to return your old short block as a core or do you still have it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2017 at 1:01AM
I am going to still have the block. Do not know what I am going to do with it. Either sell it or put it on ice.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2017 at 9:53AM
We have engine!
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2017 at 9:59AM
May as well do the oil mod whilst its on the stand and easy to access!
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2017 at 12:35PM
Clap NICE!!!
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2017 at 12:41PM
Explain the oil mod...
Marc
