  New Posts New Posts RSS Feed - 72 GTS Deuce
72 GTS Deuce
 Post Reply Post Reply Page  <1 4445464748>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2017 at 12:51PM
Depends on whether it was corrected. Does your speedo read fast or slow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2017 at 12:55PM
Change a rear end gear you must change the gear at the end of your speedo cable to match what you have. Changing tire size can do this as well (make the speedo off).
foote500 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 28-August-2017 at 1:58AM
Slow.
Marc
German Shepherd Rescue
1972 GTS "The Gray Ghost"
1967 Ford Fairlane 500
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2017 at 11:23AM
A couple of Holy Grails showed up in the post today!
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2017 at 12:33PM
Looks great.  Where'd you score those?
Did you figure out your rear end ratio yet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2017 at 12:35PM
Got them from an fellow Fairlane Club of America member. Have not gotten to the rear end things yet-that is not critical, but I will get to it, maybe next year.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2017 at 11:41AM
Did you have to sacrifice a virgin to Heathen Gods?
Those are made of pure Unobtainium.
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2017 at 1:06PM
Two virgins, and I don't mean John and Yoko.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2017 at 12:31AM
I just replaced a few bulbs on the car, and I was wondering about the trunk one, is there a mercury switch involved in that circuit?
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 25-September-2017 at 12:19PM
Was trying to replace more bulbs-what an ass pain, how do you change the bulb on the radio and the air selector,  anyone have any tips?
I was also trying to find a way to get my stock oil pressure gauge to work. See the pics of what I have now, do I need a new sender with an electrical hook as opposed to an liquid hook up? This is what I have now.
what is this thing?
And where do I find the temp sender?
Edited by foote500 - 25-September-2017 at 1:30PM
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 25-September-2017 at 5:00PM
yes it's built in the socket as best i could tell on the one in my car, mine wasn't wired up to the car so i was messing around testing it and tilted it and it went off and on Big smile
74 CORVETTE COUPE CUSTOM
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 26-September-2017 at 3:18PM
The trunk light socket has a mercury switch that is built into the trunk light socket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 26-September-2017 at 3:25PM
The temp sensor is probably located at the top of the water pump such as in between the red circle in the picture below. It might also be located at the top front of the engine block below the thermostat housing near the heater hose such as the white arrow points to in the picture below.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 26-September-2017 at 3:44PM
I have never seen a oil pressure liquid hose on a '72 like you have. On other '72 torinos if you have a standard/stock oil pressure warning light then there is a sensor/switch that connects by a wire with a connector to the oil pressure light near your speedometer.
If you have the performance instrument cluster option (oil, temp, alternator, fuel, clock and tachometer gauges) then there is an oil pressure sending unit that connects to the oil pressure gauge by a small wire with a connector that connects to the instrument cluster. Both types of oil pressure sensor/switch and sending unit are screwed into the top rear of the engine block where your liquid hose is connected to on your engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 26-September-2017 at 3:46PM
The stock/standard oil pressure sensor/switch and the performance instrument cluster option oil pressure sending unit have different part numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 26-September-2017 at 4:09PM
There is a picture below of the stock/standard oil pressure sensor/switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 26-September-2017 at 4:11PM
There is a picture below of a performance instrument cluster option oil pressure sending unit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-September-2017 at 4:44PM
the lower pic is the oil sender for a gauge! the upper pic is for a idiot light!
having a tube for the oil is an aftermarket mechanical oil gauge
never seen a sender in the pump??? it should be the one with the white arrow
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2017 at 12:15AM
I have the sport cluster.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2017 at 12:18AM
I want to get rid of the aftermarket gauges.
Marc
