  New Posts New Posts RSS Feed - 72 GTS Deuce
72 GTS Deuce
 Post Reply Post Reply Page  <1 363738
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2017 at 1:58PM
I would suggest you read this, it's full of useful info.
My 2 cents is do the lifter bore mod. It's the most effective and will cure the problem.
The oil plugs are just a band aid, it will help keep your pressure up but you will still have oil bleeding out of the lifter holes.
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2017 at 2:08PM
run a pipe from rear to front of block too
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2017 at 2:33PM
the Moroso/Roush cam bearing restrictors (drilled orifice set screws in the feed from the main saddles to the cam bearings) don't do diddly squat, the cam is getting pushed down over the oil supply holes by 16 valve springs limiting the oil flow
bushing the lifter bores www.lifterboretools.com will require complete dis-assembly (warranty void) and wash / re-assemble. it would really $uck to do that work to find out you just ate the warranty & need it. I'd run the engine as-is at least for any warranty period before taking it down ... but yes the lifter bore restrictor bushings ARE the FIX for the 351C oiling system if you're going to run it that hard
external line can't hurt unless it fails & drains your oil pan or burns your car to the ground, it just routes an oil supply to the rear of the engine (end of the system) but the lifter bores are still hemorrhaging
standard oil pump or HV?
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2017 at 3:15PM
I've had many Cleveland engines. Maybe not all out race but nice street cars. I don't understand all the bad press about the oiling system. I never had any problems whatsoever. Maybe I've been lucky, but my luck continues. I wouldn't do anything. Just my 2cents
72GTS Clint Eastwood Special                                   Â Â 2012 "SHO"
foote500 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2017 at 12:13AM
It is not going to be run hard, it is a weekend warrior. Plus I just got the assembled (minus the heads) block, do not want to take it down. If that was what I was going to do I would have done it to the block I already had. If I keep the old block, maybe I will undertake those mods. I was thinking if I keep it (and someone has already asked for it-so if it goes, it goes) I would fix it, put some 2V heads on it and have it in pocket. But I am trying to keep costs down
Marc
German Shepherd Rescue
1972 GTS "The Gray Ghost"
1967 Ford Fairlane 500
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2017 at 7:03AM
the pipe mod is bolt on.....
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2017 at 8:20AM
You just spent a pile of money on an engine with a warranty.
DON"T void the warranty.
If you want to experiment, you have the old engine.
Dissect it, build it up, while enjoying your working car with it's new, working engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2017 at 12:46PM
Indeed!
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2017 at 3:04PM
for your old block, here's one to get you thinkin
just 1 of MANY on the external line, unfortunately the link in the thread is broken & i don't know where that info is hiding ATM http://www.network54.com/Forum/119419/thread/1230874934
usually you can find a kit on ebay, the line can be rubber or metal but remember it's engine oil / pressure over the life of the hose, I'd use steel braid minimum or form a hard line  http://www.ebay.com/itm/351-C-Cleveland-CJ-400-M-Oil-System-Modification-Kit-/250510413754?hash=item3a53958fba:m:m_iHnmK5C0GONw2OEd3M57w&vxp=mtr
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2017 at 3:06PM
so what about this cam, any numbers ... brand, part number, grind number, specs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2017 at 10:42AM
I'll let you know when I go see it.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 29-March-2017 at 2:39PM
Car goes to shop tomorrow, lets hope for a better outcome.
Marc
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 29-March-2017 at 3:38PM
good luck, smoky burnout pics will be posted before ya know it
Past 1974 Ranchero GT Q code
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:54PM
Any update?
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 30 minutes ago at 5:02PM
He has the engine in, waiting for good weather to  pull it outside to start it up.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 33 minutes ago at 5:59PM
Clap Thumbs Up
74 CORVETTE COUPE CUSTOM
