  New Posts New Posts RSS Feed - 72 GTS Deuce
72 GTS Deuce
 Post Reply Post Reply Page  <1 424344
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 1:48AM
Did I miss something? Why are we changing the heads? Is the so called mechanic back to being a diagnostic parts changer or is this something you wanted to do?
Edited by 72GTS351CJ - 20-June-2017 at 2:06AM
72GTS Clint Eastwood Special
foote500 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 1:56AM
No, nothing like that, just to have if I ever rebuild the 4 bolt. Probably sell along with the car when it comes to that.
Marc
German Shepherd Rescue
1972 GTS "The Gray Ghost"
1967 Ford Fairlane 500
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 2:03AM
Upside-down and backward???
Yes, at first he said it could not be the gasket (this was before I even took the car back to him), then he diagnosed it and, lo and behold, he finds out the gaskets are directional. He said he should have it all back together by tomorrow.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 3:01AM
Ok....Good luck. ........again
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 3:15AM
It was an impulse buy...
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 4:39AM
From my mechanic:
"Morning Marc, I just finished torquing the head down, I'll make another pass thru them after I let them set for a while.  I could see for sure I had the other headgasket on backwards and it blocked a water passage."
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2017 at 5:15AM
And I apologize for the mistake and there is no charge. I hope we can get past this and you remain a customer. ....That's what I would do if I were him
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2017 at 3:20AM
I purchased this the other day, I can see it working on the GTS, but the little bump out bothers me, my intake does not have a place for that little bump, does it matter? Or will it cause a big vacuum leak?
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2017 at 9:43AM
That because it is for a 73 and up engine with an EGR exhaust port in the manifold. That looks like a non EGR spacer plate (maybe for a truck?) that allows the manifold to be interchanged for car or truck application.
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2017 at 10:19AM
Good thing I did not pay that much for it, anyone need a 73 spacer?
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2017 at 2:17PM
Would cutting off that "ear" and welding up the gap allow it to work? I cant believe there is not 1 72 spacer out there...
Edited by foote500 - 30-June-2017 at 2:21PM
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2017 at 8:43AM
all your old pics are gone, can you post a pic of your intake carb pad?
rather than cut & weld i would fill the cavity with epoxy (slightly over fill) and sand flat with a full size sheet of sandpaper on a flat surface after bringing it down with a file first
avoid filing / sanding anything but the epoxy but if you do get the metal it's no biggy as long as you finish out flat w/o course paper gouges in the metal
No, there are no 4300-D spacers out there unless you find one in a sack of hens teeth from the mid 70's. the go-to move was to bin the spreadbore and replace the intake with an aftermarket square flange & Holley
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2017 at 8:44AM
also ~ possible ~ that the 4 holes will seal and the side cavities are a non-issue?
Yes it's possible that the spacer plate may work as is with the open overhang but if your intake has the EGR passage open that may be an exhaust leak, it'll also eat the epoxy in short order
tapping & plugging the EGR passage will eliminate that problem
Edited by Rockatansky - 01-July-2017 at 8:46AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2017 at 9:04AM
i was thinking the same thing! i used body filler on the adapter plates that were on my toyota, but JB weld would work great for filling that if you even need to? i'd lay the gasket on it and see what's exposed for a vacuum leak then lay the gasket on the manifold and check for any open passages Wink
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2017 at 11:15AM
That sounds like it could work.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2017 at 2:20PM
Got the car back yesterday-no charges... Ran pretty good, minor hiccup with the throttle, seems to be hanging up a little, when coasting it was stuck around 1500 rpm, had to goose it to get it to come back down. I had a little spring rigged up to keep that from happening, but it was unhooked. So I will test it next nice day we have. The roads were a little wet last night to I got into the gas and got the wheels to spin! Happy Days!
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2017 at 2:29PM
hmm sounds like you may have a internally frayed cable
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2017 at 4:21PM
For a min I thought you said no changes... So..Good news. Hopefully you can move forward from here on
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 07-July-2017 at 6:22AM
Things are looking up!
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 07-July-2017 at 1:48PM
Actually managed to do a dry pavement burnout today-even though it was uphill and to the right! Its is running really well, I must say I am happy, I hope it does not sell.
Marc
