72 heater core w/ac replacement |
72GTS351CJ ![]() Senior Member ![]() ![]() Joined: 30-November-2010 Location: NY Status: Offline Points: 1424 |
![]() ![]() ![]() ![]() ![]() Posted: 11-January-2021 at 1:24AM |
Hi guys . I knew this day was coming. It was probably discussed before. I did a search but couldn't find an exact how to. Does anybody have any tricks to doing this enjoyable job? And while I'm there I might as well change the evap coil. -Rick-
72GTS Clint Eastwood Special
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 13037 |
no real tricks... just locate and remove the fan housing unit (a nut up by the cowl) and a couple at the bottom. then a few lag size screws and nuts some inside some outside. the hoses. and cable and vac hoses. and loosen the duct work where it attaches to the box so the box can be removed...
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 5123 |
to make the job easy, remove the outer & inner fender, pull the engine and dash
if you're going to change the blower motor, heater core and evap core you might as well go with an aftermarket unit? |
Lol. Now I'm not sure if you're joking about the aftermarket unit. ....Am I removing the dash pad or there is no reason to
i meant the whole dash, to make it easy. you can work from under the dash and through the glove box hole with the liner out, i'd pull the dash pad just to be able to see what you're doing. but really, you're replacing the fan and 2 cores why not just pitch the PITA engine bay plenum and put in a Vintage Air box? do you think the evap core really needs to be swapped?
If the evap coil makes it a game changer than its just fine.
Just looked at the manual. Makes more scents when you see pics. Basically split the air box in the car to access the h.c. Actually doesn't look that hard. I'll remove the pass seat probably easier that way . Thanks cj and rock
like Johnny said, there are some that you need to get from the engine side of the firewall and some that you get from the interior. it sucks
iirc the inside ones are down along the bottom of the box by the tranny hump and the rest outside worst is the one straight up to the cowl, not bad if you know where it is
![]() worst part is the peg clips holding the vent tubes to the box inside, they pop out but getting to a couple are a bit of a pain, just remove only the part of the vent system needed to get the box off ![]() |
Thanks for all the info. I will advise the family not to enter the garage while I'm doing this
72 RS 351 ![]() Senior Member ![]() ![]() Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 969 |
Plug your ears my dear, that's the HBO I'm listening to.
73 Ranchero GT 351C-4V 3.70 gears, to build a keeper 73 Ranchero Sport "72 front end", floor shift/console, planning EFI 351-3V &4R70W 92 Lincoln Mark VII SE, OBDII 347/4R70W |
Don't worry I'll get the air box out. It might be in 3 pieces tho
I'm sure you will get it done with little trouble. I don't remember how much it was to get the dashes out of my two when I swapped the interiors, I don't think it was that bad or I'd recall more. I have messed with some 90's dashes that were no fun, they had more wiring and more little bolts holding it all in. Do wear some gloves, they will help with some sharp edges that will scratch your hands along the way.
handsofstone ![]() Senior Member ![]() ![]() Joined: 13-April-2018 Location: Northeast Status: Offline Points: 2242 |
Please take pics along the way. I have to do the both of them in my car.
will do
Tweet
