  New Posts New Posts RSS Feed - 72 Ranchero engine mounts
shooer01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shooer01 Quote  Post ReplyReply Direct Link To This Post Topic: 72 Ranchero engine mounts
    Posted: 09-July-2018 at 4:38PM
Hi, I am after new engine mounts for my 72 Ranchero 429, there's a lot of old posts going back a few years, but apart from the Crites ones is there any other options??, I don't want weld in, the ones from Summit/Jegs are not correct, What are people using when their mounts fail???.
As I have to ship to Australia it get expensive if they are not correct.
Cheers
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2018 at 1:14PM
You could try to find OEM mounts.  Aquartlow may chime in to confirm, but I believe that the 72-79 Lincoln Mark mounts will work.
I found these on eBay that appear to be correct, but confirm with someone here first that they will work on the Torino Chassis.
1973gts View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2018 at 1:29AM
Not a cheap way to go but I am having my original mounts revulcanized by Damper Doctor out of California, should be getting them back next week and I will post photos when they get here.  With shipping it came to about $450, like I said not cheap but fitment won't be an issue and reviews on the company are good.  The mounts that Vince posted look similar but not correct for my application but may be for yours. (mine look like the third photo ones which aren't the ones for sale on the ad)
Edited by 1973gts - 13-July-2018 at 4:08AM
Dave - 1973 GTS N code
Post Options Post Options   Thanks (1) Thanks(1)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2018 at 3:37PM
The ones Vince linked to are incorrect, they are for a fullsize car. They will not work. Seller has an incorrect chart, and pictures of several different mounts.
429/460 Mounts for 72-76 Thunderbird or Mark IV, or 77-78 Mark V will work, as well as ones for a 72-76 Torino, or Montego, 72-76 Ranchero, or 74-76 Cougar.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2018 at 1:20AM
Thanks Randy, I knew someone would clear it up. That guys listing wasn't very clear. Are any of the pictures he shows the correct style mount?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shooer01 Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2018 at 12:36PM
The one in the middle of his add looks very similar, May fit but have asked him and has not got any of them.
My 72 mount
  His Mount
Edited by shooer01 - 15-July-2018 at 12:38PM
Post Options Post Options   Thanks (1) Thanks(1)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2018 at 3:59PM
the one in the middle and right appear to be part of  the correct mount. there is a bracket that goes on the engine that the insulator bolts to. Also supposed to be a pesky heat shield that goes between the two halves.
