  New Posts New Posts RSS Feed - '73 vs '72 frame-question on trans crossmember
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Topic: '73 vs '72 frame-question on trans crossmember
    Posted: 03-November-2018 at 9:34AM
Ok, tech question--
My '72 frame does not have the same transmission crossmember mount that my '73 frame does. Am I missing a mount, or does it bolt to the bottom of the frame? There are two holes on each rail, so I'm assuming I need a different mount for the '72 frame. it would be longer on each end--the '73 one bolts onto- of a welded-on plate. Am I seeing this correctly? If so, what transmission mount DO I need to find, or do I use the one from the '73 but get extensions? Not sure on this.......
Thanks, all---
Dave F
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2018 at 10:35AM
yes there are 2 different cross member styles. i've only ever owned 72 & 73's and they've all been the long cross member that bolts directly to the frame, never the had the one that bolts to brackets on the inside of the frame rails.
you have a 73 with the frame tab cross member? i'd call it a 1974+ style for clarity
but are you looking for the cross member itself or a transmission mount?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2018 at 11:52AM
Ok thanks.
So, I need a long cross-member, for what bolts to use, for a '72 gts. This is the left side for my current '73 gts. This is the frame that was originally under my '73. The '72 frame is going under as the replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2018 at 12:27PM
OK got ya, this has been discussed before swapping frames & cross members etc
if you don't turn up the long style there's no reason you can't weld on the extra length to what you have, IIRC yours is identical to the other except for the length. there's a thread with pics in it somewhere, i can't even find my pics unless ... nope already looked there
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2018 at 12:35PM
here's a pic of the long c/m from another thread
Originally posted by fordismyboss fordismyboss wrote:
Question
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2018 at 12:38PM
or surgically remove the brackets from your frame and weld them onto the new frame
it's not that hard, just grind the welds but not the brackets
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2018 at 3:15PM
I thought about grinding them off, but another forum member is interested in the frame for his car, so I'm not going to grind anything off unless he decides either not to take it, or tak just the back half. Otherwise, I'll need to know what cars would be the donors.....
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2018 at 4:46PM
 any of the 72 torino,montego, ranchero wagon.... should have the longer cross member
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2018 at 12:20AM
I should probably ask (now that I found the crossmember forums)..... The '73 was originally 351c (q code), but previous owner installed a 429/460. I'll probably go back to a 351c, since I have one for it, but may still build the 429..... Both will be on stands in the meantime. Is the crossmember the same for either engine?
I may just end up grinding the welds to pull the brackets.....seems like the best choice
Edited by hogfiddles - 04-November-2018 at 2:34AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2018 at 2:33AM
Yes, the cross member is the same for both engines.  I think it might be easier to cut the brackets off the '73 frame than to find a longer cross member.  If you do find a longer cross member, here is a thread that shows how to make up some mounting bolts:
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2018 at 2:36AM
Cool.....thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 07-November-2018 at 3:47AM
Use a cutoff wheel and cut the welds. Take lots of measurements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 07-November-2018 at 12:21PM
don't you have pick-n-pulls there?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 09-November-2018 at 8:40AM
Other option is to make/get made a couple plates (Similar to the pieces for a 73-up frame) that you can bolt to the frame and will attach to the existing crossmember.
Make 2 bolt holes to attach to the frame in each to spread the load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 09-November-2018 at 9:49AM
a couple heavy L brackets would do the trick,
let the trans & mount do the locating and 2 self tappers on each side would be enough to drive it to get it welded if need be
Edited by Rockatansky - 09-November-2018 at 9:50AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 09-November-2018 at 10:29AM
Found one on eBay.....now I just gotta wait for the guy with the brown shorts to drop it off
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 09-November-2018 at 10:37AM
and find / make hardware Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 11-November-2018 at 1:41AM
Yup:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 11-November-2018 at 2:11AM
Yup:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2018 at 10:52AM
YAAY! My crossmember arrived in the mail today:). I just have to re-shape on one the bolt holes. I guess someone had to torch off the head of a bolt and it uglier up one of the holes. I'll fill it it with weld then grind to reshape.
Now, question on the 'clip-nut''. I saw the other post on how to make a replacement......but my question---- does the original retaining nut/clip happen to be the same thing that was used to hold the front bumper mounts onto the '73+ front frame horns? If so, I have a couple to use :) if not,well..... I still have a couple.
Dfox
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2018 at 1:41PM
i think somebody said they were...???
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 25-November-2018 at 1:54AM
Anyone have a pic of an original '72 crossmember-to-frame nut/ bolt combination?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 25-November-2018 at 1:21PM
I am not sure if anyone has a picture of an intact setup, but this is the best I could come up with.  There are some more pics in this thread:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 25-November-2018 at 3:06PM
google the PN for a pic, images ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 25-November-2018 at 4:16PM
I tried googling, but didn't find anything
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 25-November-2018 at 4:21PM
Ah, ha!! I suspected as such, and there is the answer in that other forum--- the nut-clip is indeed the same thing as the front of '73 for the impact bumper mounts!! I have two of those so I'm good!! Yaaay!!!
Dfox
