  New Posts New Posts RSS Feed - 74 Torino Doors & Roof
Torino Pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torino Pete Quote  Post ReplyReply Direct Link To This Post Topic: 74 Torino Doors & Roof
    Posted: 23-December-2020 at 9:53AM
Good day!
I am a new member and am excited to join the forum! I am the proud owner of a 74 Gran Torino 2-door which I am restoring with my son. I'm currently trying to source a roof skin and a set of doors in good condition since the originals would require a substantial amount of sheet metal work to restore.  Any suggestions would be greatly appreciated.
The only doors I found so far are from a Ranchero of the same year on car-part.com.  If anyone can confirm interchangeability that would be great too!
Thanks,
TP
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2020 at 12:37PM
i have that stuff but i'm in washington state, and shipping large items has been near impossible  latelyCry
 but yes 72-76 ranchero doors will fit , just swap the glass as they use different glass!
 welcome BTW!Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2020 at 1:47AM
Welcome to the forum.  You've been upgraded to a new member so you have full forum access.  As John stated the doors are interchangeable with a Ranchero, but the glass is different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torino Pete Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2020 at 2:50PM
Thanks much for the welcome and the feedback! I can look into shipping options if you can provide a few details and pics of the doors and a roof skin if you have that too. Thanks again.
TP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torino Pete Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2020 at 2:53PM
Thank you and glad to be upgraded!  Great to be here!!
TP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 02-January-2021 at 9:21AM
72-76 torino bolt on fit
 72-76 ranchero doors the same you need your glass.
watch out for power windows vs manual the glass is different at the bottom to make clearance for the power window motor. you can get away with using a power window glass in a manual door but not the other way around! Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 02-January-2021 at 2:41PM
Okay, really, the manual glass cannot be used with power window actuators etc? i have two pairs of glass, I guess I will need another most likely.Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-January-2021 at 6:00AM
i've never checked but sal and carl both reversed the actuators and said the regular glass will clear....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 03-January-2021 at 3:02PM
Do you mean the window regulators? I found a pair of NOS regulators many years ago, and the rebuilt Ford window motors used to be easy to get, and about $35 each back then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-January-2021 at 4:26PM
yeah from what i understood they swapped regulators side for side and the glass just clears the motors??? idk if they had to mount them upside down or what idk???
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2021 at 3:01AM
Thanks, that is interesting. I'll want to look into that earlier on, in case I need to hunt other window glass. I bought spares 25+ years ago from a later Ranchero, two with no scratches in them.
jversch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jversch Quote  Post ReplyReply Direct Link To This Post Posted: 12-January-2021 at 5:45AM
Have you found doors and a roof ? I may be able to help you . Are you looking for sport roof or formal . i live in Rochester area , only about a hour away . No shipping needed.
Jerry VerSchneider
