  New Posts New Posts RSS Feed - 76 Gran Torino 351w diesel motor swap
Lnavarre View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lnavarre Quote  Post ReplyReply Direct Link To This Post Topic: 76 Gran Torino 351w diesel motor swap
    Posted: 12-October-2017 at 3:14PM
Looking for info on what would be required to swap 351w for a cummins or powerstroke. I know it won't be easy will need to highly modify vehicle but just wanting info about cost and what to expect.
Edited by Lnavarre - 12-October-2017 at 3:14PM
jversch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jversch Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2017 at 2:16AM
don't know if it has ever been done
Jerry VerSchneider
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lnavarre Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2017 at 7:21AM
I've seen a duramax in a 75 cutlass, so I'm guessing it would be a similar situation
Edited by Lnavarre - 13-October-2017 at 7:21AM
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2017 at 10:18AM
Seen a Cummins in a Chevelle and they're the same size.
However you would need to do the following, section the fire wall and recess engine (too much weight in front of axle centreline if not)
Brace frame (heavy things, more so than a 385)
Custom sump as they're a tall engine
Custom turbo manifold for clearance
Adapter to TH400/C6 or run the Alison
Barnaby
qcode72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote qcode72 Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2017 at 1:18PM
check out the cummins website,alot of info there.
