  New Posts New Posts RSS Feed - 77 wagon frame
77 wagon frame
torinojon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Topic: 77 wagon frame
    Posted: 19-May-2018 at 11:29AM
i was wondering if any one has put a 1972 ranchero frame under a 1977 wagon body.are the body mounts the same.i thought theres a difference in the body mounts location.i got a chance to get a rust free body and frame (not much more) to do the swap.let me no what you think...thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2018 at 7:26PM
are the wheel bases the same? 72 cars had an extra body mount near the top of the rear axle arch that was deleted on the later cars, and the 72 ranchero frames had a pair of rubber bushings inboard on the axle arch crossmember but they only sit against the bed floor for support not bolted! just basically pads so that may not matter? that's about as much as i can tell you, unfortunately i scrapped the 72 ranch frame i had so i can't take any measurements off of it for you Cry
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2018 at 9:10PM
What kind of '77 wagon?  It would have to be either a 77 LTD II or Cougar, both of which are not that easy to find.
Either way, when I had picked up a receiver hitch from a 77-79 Ranchero, I discovered that the back end of the frame of the Ranchero was different than my 76 Montego wagon, and the hitch would not work on my wagon.  I'm assuming all 72 - 79 Rancheros are the same.  And all 72 - 77 wagons are the same.  Although maybe there are some slight differences with the 72 like John mentioned.  At the rear of the vehicle, one of the frames is parallel to the ground.  While, on the other vehicle, the frame angles up.  I can't remember which was which (wagon vs Ranchero).  I can look at my Montego wagon tomorrow to confirm.
Jeff
79 Ford Thunderbird w/ T-tops
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2018 at 2:48PM
Frames behind the rear axle are different. Ranchero and wagon mount gas tanks in different locations. Wagon had the cargo well or rear seat well and tank on the side. ranchero had a underbody tank. Wagon got a 5 MPH rear bumper with energy absorbers, but Ranchero was a truck and kept 72-73 type bumper.
2005 F-150 STX 4.6, 3.55 LSD
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2018 at 3:41PM
the factory chassis manual should show top & side views of each frame with measurements
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2018 at 3:31PM
Interesting. I have held onto a perfect '74 Ranchero frame in case I needed one for either of my wagons. If they are different, to scrap it goes.
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 10-August-2018 at 10:53AM
The 72-79 ranchero and the 72-76 torino/montego wagon and the 77-LTD II/couger wagon frame are all the same EXCEPT for the front bumper mounting on the 72 and the rear bumper mounting on the wagons after 73.  There are some other small differences but the bodies for any of these cars will bolt right on to any of the frames mentioned.
