  New Posts New Posts RSS Feed - 9 inch rear end question
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Topic: 9 inch rear end question
    Posted: 13-January-2018 at 2:08AM
Since I am parting out the 1964 Galaxie, does anyone know if the 9 inch center chunk out of it will interchange with one out of a 1973 to 1979? The car may have a good gear ratio and I don't want to get rid of something I could use. Housings are completely different, but perhaps it could be put to some use elsewhere.
Edited by unlovedford - 13-January-2018 at 2:10AM
1972 GTSquire Wagon
jbach72gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbach72gts Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2018 at 2:27AM
It will if both were 9 inch housings
Ford equipped some 302 powered mid sized cars with 8 inch so be cautious
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2018 at 2:42AM
See the fill plug in the rear of the axle housing?
That means (If it's the original center chunk) that there is no fill plug in the centersection.
It can be drilled/tapped for a plug, or the guts swap to other chunks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2018 at 9:20AM
You can also fill the housing before re-installing one of the axles if there is no fill plug in the center section(and not wanting to drill/weld for a drain plug). Since the axles are already out while swapping center sections, it isn't too bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2018 at 1:02PM
take the breather tube fitting out to fill....
