  New Posts New Posts RSS Feed - A/C Oil capacity
A/C Oil capacity
sbeusch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sbeusch Quote  Post ReplyReply Direct Link To This Post Topic: A/C Oil capacity
    Posted: 30-September-2018 at 7:00AM
we have a 1973 Ford Ranchero GT 351 Cleveland and just got a new A/c Compressor
Four Seasons #58022 and can't find what type oil and capacity.  Their chart says see the under hood specs.  there are none.  Can anyone help
thanks
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2018 at 12:18PM
I looked it up in the factory service manual for you.  There is no specification on the oil quantity.  It just states to drain the ooil and measure how much was removed.  There is also a procedure to fabricate a dip stick to check the oil level in the compressor.
Edited by 72FordGTS - 03-October-2018 at 1:04PM
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2018 at 12:53PM
Are you running r12 or 134. I believe they call for different oil. When I filled mine it specified how much and which oil. I'll look for the directions tomorrow. I believe it is a York compressor
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2018 at 3:00PM
did the York / Tecumseh compressors keep an oil level in the compressor crankcase and also use a circulating oil charge in the refrigerant?
or just in the crankcase, or just in the refrigerant?
is there a fill / level plug?
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2018 at 3:10PM
Definitely different oils for use with different refrigerants. R12 use 525 mineral oil, for 134a use PAG 100 oil(recommended for use in York or Tecumseh style compressor). Oil capacity depends on a few factors, refrigerant type and if it's a partial or total refill. R12 system would use around a total of 8 to 9oz of 525 oil and 4lbs +/- refrigerant, 134a would be a bit less for both oil/refrigerant. I would recommend keeping the STV/POA valve and adjust it if using 134a, the York/Tecumseh style of compressor clutch does not like the type of cycling newer vehicle A/C systems employ. Just an FYI.
