  New Posts New Posts RSS Feed - a few electronics questions
tom72torino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom72torino Quote  Post ReplyReply Direct Link To This Post Topic: a few electronics questions
    Posted: 06-February-2018 at 11:45PM
Hi Guys!
I'm just changing my turn signal switch. How do I get this steering column shroud of? It looks like this:
...and consists of 2 parts, but without screws.
That means they have to be clipped somehow.
I'm also looking for the right turn signal switch for my 72 gran torino.
Mounted in my car behind a standard 2 spoke steering wheel is this one:
This would, however, according to my research of a 71er be.
I have only ever found the one for the 72 model with this layout here:
Which is the right one now? Confused
One more question about the horn. Currently only one horn is installed and I want to switch to a 2-tone horn. One for high pitch and one for low pitch. I could not find any relay. Is no relay installed in the 72er? Can I just switch to 2 horns without an relay?
My rim blow button for the horn does not work properly and the original part is too expensive for me. Therefore, I want to install a small switch behind the steering wheel pad on the left and right of the 2-spoke steering wheel pad. How many amps does a horn draw normally or 2 horns? So that I can get a suitable switch, which is sufficiently dimensioned. Is a 3 amps switch sufficient?
Thanks a lot for your help!Big smile
Best greetings from over the big pond from Austria!
Thomas
Have a nice day!
Greetings from austria!
Thomas
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 07-February-2018 at 6:00PM
the plastic collar has 2 screws and it clips together but there are 2 plastic pegs on the end that slide off...one section slides off of the other. go easy and slow the pegs get messed up easy
the switch in the rock auto pic looks correct
the horns on these cars don't use a relay, they have positive power in and positive power out.
as far as duel horns there's a jumper wire that feeds both horns, it plugs into your single horn wire at the horn btw i have that wire Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom72torino Quote  Post ReplyReply Direct Link To This Post Posted: 07-February-2018 at 7:21PM
There are no screws. I have already tried to slide off. Then I'll take a closer look at it again. Wacko
Although I'm still unsure, since this one of the 71er looks more like mine......
....but I will order the turn signal switch from the '72 and hope that it will work. Wink
So only a cable from the positive connection from the first horn to the positive connection of the second horn is placed?
Great John, then I would be interested in the cable! Thumbs Up Send you a pm.
Have a nice day!
Thomas
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2018 at 3:26PM
yes if you have 1 horn, unplug the connector at the horn the jumper wire plugs into your wire, 1 connector on it plugs onto 1 horn, the other connector plugs onto the second hornWink
got your PM Big smile
AgentCooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AgentCooper Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2018 at 4:05PM
Mhh similar question here, I want to replace my signal turn, Gran Torino 75.... any idea where I can found which part works for me? The only tool that I have is search on ebay "gran torino 75 turn signal".... :S
The owls are not what they seem
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2018 at 4:31PM
it should look like this...
NOS-73-74-75-76-Torino-Turn-Signal-Directional-Switch-D3OZ-13341-A-Ranchero
this is a good pic showing the 2 copper pegs for the horn contact
Post Options Post Options   Thanks (0) Thanks(0)   Quote AgentCooper Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2018 at 4:33PM
Do you have one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2018 at 4:36PM
i should have 1 or 2?
