AC part question |
Montego01
Senior Member Joined: 16-December-2012 Location: Largo Status: Offline Points: 565 |
Posted: 20-July-2014 at 7:15AM |
What do you call the part I have circled in the image below? And it's purpose? |
i believe it's called a receiver dryer, it's basically a filter
http://www.carparts.com/classroom/ac1.htm |
what he said \/ \/ it's been a while the R/D is up front by the condenser =================================== early systems use a R/D, later systems use an Accumulator the R/D guarantees liquid to the Condenser, while the Accumulator prevents liquid to the Compressor =================================== I think I got it that time. i'll now step AWAY from the screwdriver before I hurt myself Edited by Rockatansky - 20-July-2014 at 10:23AM |
mcford
that is the accumulator. reciever drier is connected to the side of the condensor.
i thought at first it was called an accumulator, but i couldn't remember so i looked it up on the internet (guess you can't believe everything you read on the internet)
aquartlow
Here is a description of the accumulator's function.
Note: Some of Ford's A/C systems did not require an accumulator. Those that used an A6 a/c compressor(75-76 Tbird and/or Lincolns) are an example. Todd
Montego01
Great...thanks for the info.
I did notice though that I saw some systems changed out with the Sanden compressor and new lines and the system did not have it. So like Todd mentioned, I guess some of the systems did not need it possibly depending on the compressor.
That's a good thing if I end up changing the system over....seems I may not even need to look for one :) |
GranTorinoSport
I was wondering about that part also because from what I have read accumulators are used in systems that use an orifice tube. Our systems use a suction throttle valve and generally would not need an accumulator. It is interesting to note above that changeover to a modern style compressor negates the need for it. Since I am putting together my system, I would like to verify it isn't needed since I plan to use a sanden style compressor.
Webmaster |
aquartlow
Scott,
Not sure what brackets you are using for the A/C and/or PS pump, but this modern A6 replacement is available, uses Nippondenso internals and is supposed to be a direct replacement for an A6(uses the original brackets AND hoses). I am going to replace my A6 with this unit. Here is another style of A6 replacement from Delco/4 seasons, also uses factory brackets/hoses, can be found on Rockauto.com. They were once called a "Pro6ten" compressor and sold by Classic Auto Air, but they are now found under the Delco/4 seasons name. I have heard/read that this compressor is based on a Sanden unit, but not 100% sure. Good luck. Todd
Edited by aquartlow - 21-July-2014 at 3:36AM |
gpd294
Senior Member Joined: 18-September-2008 Location: Dallas, Texas Status: Offline Points: 2180 |
I have one that I cleaned up and painted prior to switching over to the new Sanden system. Let me know if you decide that you will need one. As a matter of fact I have the old compressor as well.
GranTorinoSport
Todd I do not have a bracket yet but I am using stock brackets and pulleys for a 78 f250. I think the traditional York plate would fit in that combo, but is the A6 bracket similar? This would be for a big block, which may be an issue since they did not have car big blocks past 76 and didn't use an A6 until like 78? Or maybe it fits in the same location?
Webmaster |
aquartlow
Scott,
The York compressor uses a totally different bracket compared to an A6. Here is a pic or 2 of 429-460 brackets that allow an A6 and Saginaw PS pump to be installed into an intermediate without any issues with the front DS control arm. This pic shows the larger bracket which holds both the Saginaw PS pump and an A6 compressor with the use of the "C" bracket that attaches to the front of the compressor. This pic is of the main bracket that bolts to the 460's head/block on the DS behind the larger "flat bracket that attaches the PS pump/A6. Here they are installed on my '79 Ranchero. There is another 460 bracket that allows the install of a Saginaw PS pump and A6 compressor but it mounts the A6 further back towards the firewall where it WILL interfere with the DS upper control arm and/or mount. Here is a pic, you can see the differences between the two. Here are two pics showing the A6's attachment bracket that shows how much it moves the compressor rearward. In this pic it shows the "C" bracket and it is basically flat. This shows both a/c compressor brackets, both for an A6. The left one, "C" bracket moves the compressor forward. The right one, fully circular bracket, shows the bend in the bracket which moves the compressor rearward causing the compressor to hit/interfere with the DS upper control arm and/or UCA mount. Sorry for the long post and not a "yes" or "no" answer, I figured the info could possibly be helpful. Todd
Edited by aquartlow - 21-July-2014 at 7:21AM |
Montego01
Thanks everyone that replied to this thread.
My ac is a factory installed system using the York. So I have all the brackets except the adapter bracket for the Sanden which seems to be available.
I've decided just to use the Sanden. Looks like a nice setup Todd. Looks to be kind of reverse of the York setup where the compressor is on top and the power steering pump is on bottom. I have a more recent thread started...should probably just close this one - thanks |
lewistg
New Member Joined: 08-August-2017 Location: MS Status: Offline Points: 3 |
I just ran across this post. I am in need of the horseshoe brackets for my engine. Or does anyone sell a conversion bracket?
lewistg
Aquartlow, where can i find the article u shared?
aquartlow
Which article? I highlighted a couple. BTW, Welcome to the forum, I see that this is just your second reply/posting. I will be happy to help if possible.
As far as the bracket...I have a complete set of A/C, PS brackets/plate/mounting base, but looking to keep them as they are getting VERY difficult to find. You can find these brackets on mid 70's BBF Lincolns, big Ford the Mercury's can be different, just need to pay attention to the A/C bracket. I do not know of anyone making these. Edited by aquartlow - 08-August-2017 at 1:56AM |
lewistg
The article from super motors with the pictures of the different brackets.
aquartlow
If you look at my signature at the bottom of any of my replies/posts you will see my Supermotors link. Basically shows what I have done to my Ranchero over the years, too bad I have left A LOT of pics unposted and/or lost between computer "changes".
