Accelerator cable |
GranTorinoSport
Posted: 15-October-2013 at 5:17AM |
Switching from 351W to 521 means my accelerator cable will no longer work.
Other than waiting for and overpriced one to come available on eBay, has anyone used Lokar? |
Webmaster |
Psquare75
Mark used the generic Spectre one on his Cougar with ok results.
GranTorinoSport
Paul,
I took a look at that. It seems to have the same pedal end as the Lokar. The part I am having the most problem with is how to adapt the Lokar (or Spectre) end to the Ford pedal assembly. Otherwise I think it is a fairly straight forward install (but I expect it will take time and patience). |
Webmaster |
GranTorinoSport
So I have been hunting around and these photos from TheCorral.net seem to be the most coherent:
Webmaster |
Psquare75
I think that's about what he did. I don't recall.
ramair351
Senior Member Joined: 08-May-2006 Location: west michigan Status: Offline Points: 1561 |
is the 351w cable too long or too short for the BB?
-Pete
1972 montego GT 1970 Torino cobra SCJ 1970 mustang mach 1 1965 Falcon futura |
I gleaked a throttle cable from a late 60's 429 LTD, it's longer than the stock 72+ intermediate cable
it also had a 3.25 / 9.3" center |
mlachance112785
Senior Member Joined: 31-May-2012 Location: Dighton, MA Status: Offline Points: 343 |
I'll chime in.
I did use the Spectre kit. I broke the first one I put it. I got a little over-zealous and stuffed the pedal too hard/didn't leave enough slack on the cable. No issues with the second one. I think the early pedals were different though. That might be why you had an issue. I don't remember. I tried grabbing a cable from an early 70's Lincoln, but the end that hooks to the gas pedal was different. That's how I ended up with the universal cable. Ugh.
77 Cougar XR7 460/C6
Ooops, I think I meant it was a Galaxie... but both ends are the same as the 72 cable, swapped right in no issues |
i didn't change throttle cables on my car as i only changed intakes and carb,but for what it's worth i did use lokar's tv kickdown cable, works well, if thats next on your list
