  New Posts New Posts RSS Feed - accessory brackets
accessory brackets
ssregal39 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssregal39 Quote  Post ReplyReply Direct Link To This Post Topic: accessory brackets
    Posted: 19-February-2016 at 11:45AM
Hi all I have 78 bird with a 302. I want to put in a 351. Will all the accessory brackets line up or do I need others?
thanks in advance Wink
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2016 at 11:47AM
no you need the 351 brackets
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssregal39 Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2016 at 11:55AM
Not yet. As of now I'm curious if they're different and if they are what is different.
I still need to find a 351. Not easy to find for some reason here in Virginia Beach.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2016 at 12:17PM
its even harder finding a decent engine where I am!
But you need the correct brackets for the application unless you buy a conversion style kit with the serpentine belt or billet brackets
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssregal39 Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2016 at 12:24PM
Ok I guess that's what I needed to know.
I have zero ford knowledge, all Chevy.
what about a later model, say an F250 with a serpentine. Will all that fit between the wells? The ac would have to be adapted of course.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2016 at 12:30PM
possibly....not really sure, I'm into big blocks and no creature comforts. Don't even have a heater in mine....just PAS and an alternator
What I can tell you though is the 429 brackets are different to the 351 brackets and the 302 brackets will be different again
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssregal39 Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2016 at 12:35PM
Cool thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2016 at 1:01PM
351 W??? i may have some of the brackets (for a 351W)
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssregal39 Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2016 at 1:07PM
I'm interested if you have some.
which ones are different? I'm assuming a/c and alternator are different?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2016 at 2:58PM
302 brackets MAY fit on a 351W.
Depends on year and options. the only difference is deck height. Some years had brackets with extra holes. Some had a big main plate to mount everything on. others have half-a-dozen or more small brackets. (take a picture before disassembling)
2005 F-150 STX 4.6, 3.55 LSD
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2016 at 4:50PM
i have the p/s and lower alternator bracket, i'll have to look and see if i have the upper one somewhere (no a/c) and possibly the pulleys too (stock v belt)
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssregal39 Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2016 at 1:27PM
Ok cool.
