  New Posts New Posts RSS Feed - Adding a second temp sensor-ideas?
russosborne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Topic: Adding a second temp sensor-ideas?
    Posted: 23-December-2018 at 7:39PM
I need to add a real temp sensor for my electric fan, to replace the temporary one I am using that just has a probe that goes in the radiator fins. It works, but was always intended just to get the car on the road until I could do it right.
Seeing as these engines have a dry intake I am really out of ideas.
The only one I really have is to add a sensor into the upper radiator hose. Not thrilled with the idea, it looks cheap, but if that is the only way I will have to do that. I do have the adapter thing that you cut the hose and put this in the middle already and a BMW 2 temp sensor, since I have the 2 speed Lincoln fan.
I've heard about doing it in the heater hose, but I am not too sure about that. If the heater isn't on, does the coolant still flow in the hoses?
Anyone have any ideas on how to add one to the engine itself, or that has done the heater hose version? When I first started this I didn't know about the dry intake. Thought it would be easy to just tap into it. CryDead
Thanks,
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2018 at 12:41AM
I run dual electric cooling fans with two separate Derale controllers and I installed a "T" (to allow the secondary fan's sensor to be installed) in my heater hose that leads to the heater core using parts sourced from Lowes due to them being metal and not plastic, works great and I have had no issues with it. I will tell you I use adjustable temp controllers and the senders do not have to be grounded to work correctly. The black iron "T" I used has the straight through portion of the fitting with brass 5/8" heater hose barb fittings installed and the 3rd leg came with 3/8" NPT that needed no adapter for the Derale sender. Prior to installation you can prime and paint the "T" fitting black to be much less noticeable. Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2018 at 1:03AM
Thanks.
That could work.
Think my BMW sensor is metric, but I can work around that.
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2018 at 7:10AM
cleveland? both of the clevelands in the parts cars had a sensor in the thermostat water neck for a smog fitting temp sensor besides the temp gauge sensor down in the block  i should have 1 of laying around in the garage...
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2018 at 8:08AM
Yep.
That would be what I really need if you have any. Thanks,
Russ
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2018 at 9:55AM
I have the EFI sensor by the thermostat, and a second sensor for a gauge in the water pump. Reading differ by 3-5 generally (water pump reads a bit cooler).
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2018 at 2:11PM
 russ, i'll look for it when i got back out to the garage in a few.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2018 at 6:33PM
Thanks.
No rush though, going to be a bit and a half or more before I get really back to the Ranchero.
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2018 at 6:50PM
 Embarrassed oops sorry i went out there and forgot, i will look...
