Aftermarket steering wheels - what looks at home? |
Dubz
Member Joined: 26-April-2020 Location: Manitoba Status: Offline Points: 49 |
Posted: 03-September-2020 at 3:09AM |
Hi guys,
My steering wheel is cracked, and the large diameter wheel makes the car a bit harder to get into with my racing buckets. I think a smaller diameter wheel might be a good move to make the steering feel a bit more responsive, although I'm fairly certain the power steering might be more of the culprit. Summit suggests a Grant 1902 based on my model/year, but I imagine anything would fit. What's everyone got?
1974 Gran Torino in flat black 351W/C6
stock wheel is 14" dia.
grant #773 is blk 13" GT signature series... i have a 12" version on my car grant #772 |
aquartlow
I use this exact wheel on mine, 13" version. Still have the GT horn button, been there for almost 30 years. Jeesh I'm getting old.
Admin Group GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Online Points: 5846 |
I can't comment on the aftermarket wheel, but if you want to improve the steering feel, you need a new steering box. There are two options, a Lares quick ratio, or swapping to a Saginaw steering box.
Dubz
Awesome! I'll look into that PS swap as well, that would be a great addition.
EvilScientistMoose
New Member Joined: 15-November-2020 Location: Bend, Oregon Status: Offline Points: 13 |
I am currently swapping to a Saginaw quick-ratio box in my '76 Ranchero (the original is a two-bolt Ford), is a different pitman arm also required?
72 RS 351
Thanks(1)
I don't know what new issues or details have been found since I did my conversion, in 1988. I bought a Saginaw steering box from a 71-73 Mustang, and sent it off to be rebuilt by the same builder doing NASCAR boxes. I don't think there is any difference in the pitman arm, I used a new one for my 72 Ranchero then. I learned by phone then that lots of OEM cars had compatible Saginaw boxes in them. In the 80s' a Trans Am was a more common car to find than the 71-73 Mustang, I'd have hunted one of those if I knew before the Mustang I found. The first thing to look for was the number of bolts on the cover visible from directly above. The two bolt type are not a Saginaw box for sure, those all have four cover bolts, that can work. That's all I recall learning back then.
handsofstone
Thanks(1)
This one was put in my car after a 39 year slumber in the basement.
Senior Member Joined: 08-June-2019 Location: Florida Status: Offline Points: 1755 |
I used one from a 1976 Mustang ll. The Maverick, Pinto and Bronco all used this steering wheel as an option.
handsofstone
Looks like you need a tilt column.
That is a tilt column! I had to use that angle to get a decent shot of the steering wheel
BadHabit351
Senior Member Joined: 21-June-2013 Location: United States Status: Offline Points: 217 |
Grant Wheels 9660. It's 15" and combined with my Lares quick ratio steering box works well. It also has enough dish that it doesn't cause your fingers to interfere with the turn signal stalk or the ignition switch. As a bonus; my car is built as period-ish hot rod, so it matches the style of the car.
1973/72 Gran Torino Sport
1971 Torino GT convertilble 2013 Ford Fusion 2004 Ford SuperDuty 2013 Mustang GT |
paj1965
Member Joined: 18-August-2017 Location: Houston TX Status: Offline Points: 128 |
I have this one, too. Love it. Great size and feel.
My Toy List:
1972.5 Gran Torino Sport 2001 Mustang Cobra Vert 2001 Lightning 2013 Jeep Wrangler |
SunsetSeizin73
New Member Joined: 05-December-2021 Location: San Diego, Ca Status: Offline Points: 9 |
I've been thinking i should do the same Grang 9660 swap. Looks great! What install kit did you use?
Thanks, Matt 1973 Grant Torion 351c/4spd Q-Code |
grant #3249 for the kit
72 RS 351
I think that's the steering wheel I have in my old 73, but the spokes were a little rusty when I got the truck. It's a very good looking wheel, mine I was thinking of coating the spokes in black, back in the late 80's.
