  New Posts New Posts RSS Feed - Airbrush Touch-ups
Airbrush Touch-ups
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Topic: Airbrush Touch-ups
    Posted: 13-April-2017 at 1:06PM
I am not a body many or painter by any stretch, but I try my best.  My daily driver truck has a small spot that I need to touch up, about the size of a dime.  I tried to use a spray can to do it, and it just looks bad.
So I was thinking of buying an airbrush and trying to learn to use one?  It seems like with some practice I might get some good results.
Any one here use an airbrush?
What is a good brand/make to buy?
How much do you need to thin the paint?
Can you spray clear with them?
Any advice is appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2017 at 4:56PM
i do, but i'm not an artist! (some people seem to think i am) i have a badger 150, a cheap knock off of the badger, and my favorite.. an iwata air brush Big smile the iwata is awesome! i can't remember the model off the top of my head... i can check later.
yes you need to thin the paint a little more
yes you can spray clear through it , just thin a little more Wink
 and i have a sata mini gun that's great for touch up!!! it's about half way between a paint gun and an airbrush Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 14-April-2017 at 10:05AM
With practice, they work good,
You can mask right on the edge of a stone chip and fill/paint without major blending.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 14-April-2017 at 12:04PM
Thanks guys, maybe I will give it a shot.
Can you hook them up to a normal air compressor?
I assume you just use reducer as you would for a normal paint gun to thin it out?  I read some stuff online where guys were using lacquer thinner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 14-April-2017 at 12:24PM
you could use a normal compressor, but you will really have to choke the air pressure and volume down.
You can get small air pumps that will work easier/simpler.
As far as reduction, use whatever is correct for the paint. Some things may not be compatible with the chemistry of the paint. If you are just using the little touch-up bottle paints, and shooting that thru the airbrush, I would check with the manufacturer for what they recommend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 16-April-2017 at 4:09AM
Thanks Randy!
I do have a small 8 gallon compressor besides my big one.  I just didn't want to buy another little compressor when I already have a couple.
I'd probably just get a paint shop to mix up a small can of paint. I will just used what ever they recommend as a reducer then.
