  New Posts New Posts RSS Feed - Another small block advice thread
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 10-February-2017 at 12:37PM
I fixed the link:
https://www.summitracing.com/parts/lun-10350701
The specs are below:
UPC: 788120715676
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,000-5,500
Intake Duration at 050 inch Lift: 213
Exhaust Duration at 050 inch Lift: 219
Advertised Intake Duration: 256
Advertised Exhaust Duration: 262
Intake Valve Lift with Factory Rocker Arm Ratio: 0.483 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.499 in.
Lobe Separation (degrees): 112
Computer-Controlled Compatible: No
Valve Springs Required: Yes
Edited by dave302 - 10-February-2017 at 12:43PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 10-February-2017 at 12:43PM
If you stick with the 302, 2 1/2" duals is a bit large,
a cam for a 351W will fit, the engine will need to run the 351 firing order.
a 351 cam will act more radical in a 302, so a cam that is a little lumpy in a 351 will be noticeably lumpier in a 302.
Finned valve covers will not only add horsepower, but at least 20 MPH on the top end and double fuel mileage.
3.50 gears will make the car a LOT more fun, but will make the car busier at expressway speeds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-February-2017 at 5:48PM
^^^ oh that's right! Shocked yes those fins will allow the air to flow over those fins lengthwise, and should increase your top speed, especially if they are the old cal custom style fins!!! and make it more stable on the straight a ways WinkLOL
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2017 at 6:14AM
it just so happens that they are old cal custom valve covers.
Jeff
79 Ford Thunderbird w/ T-tops
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2017 at 8:05AM
Anyone know what compression on my 302 should be? Stock 79 bored .030 over.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2017 at 8:29AM
now this would be a nice addition to all that and would fit all under the hood and really wake that car up a bit!!!Big smile
http://www.ebay.com/itm/TORQSTORM-SUPERCHARGER-SYSTEM-SMALL-BLOCK-FORD-302-351W-ARP-K-FD302-/272255574200?hash=item3f63b260b8:g:-GcAAOSwBahVfZJG&vxp=mtr
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2017 at 9:13AM
8:1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2017 at 10:03AM
'rebuilder' pistons usually over compensate for the increased bore diameter with an excessing capacity dish to prevent the rebuilt engine from getting into an octane requirement problem
if you're going to re-cam the engine using the existing bottom end, make sure you don't choose a cam that asks for more static compression ratio than you have, overall performance will suffer due to reduced cylinder pressure. in general performance cams assume that you will have better than stock static CR, you'll want to choose a cam that improves cylinder pressure. indicators will be short advertised and .050" duration numbers and low or no overlap at all
the 'hotter' the cam the more static CR it wants
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2017 at 4:45AM
Any recommendations on ignition?  Will my existing Duraspark II be sufficient?  I found this post on HAMB, where a couple of folks actually recommended the Duraspark over HEI and others.
Jeff
