Another small block advice thread |
Page <12 |
Author | ||
dave302 ![]() Senior Member ![]() Joined: 08-October-2009 Location: usa Status: Offline Points: 3170 |
I fixed the link: https://www.summitracing.com/parts/lun-10350701The specs are below: UPC: 788120715676Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 1,000-5,500 Intake Duration at 050 inch Lift: 213 Exhaust Duration at 050 inch Lift: 219 Advertised Intake Duration: 256 Advertised Exhaust Duration: 262 Intake Valve Lift with Factory Rocker Arm Ratio: 0.483 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.499 in. Lobe Separation (degrees): 112 Computer-Controlled Compatible: No Valve Springs Required: Yes Edited by dave302 - 10-February-2017 at 12:43PM |
Big Bird ![]() Senior Member ![]() ![]() Joined: 25-August-2013 Location: New York Status: Offline Points: 3934 |
If you stick with the 302, 2 1/2" duals is a bit large,
a cam for a 351W will fit, the engine will need to run the 351 firing order. a 351 cam will act more radical in a 302, so a cam that is a little lumpy in a 351 will be noticeably lumpier in a 302. Finned valve covers will not only add horsepower, but at least 20 MPH on the top end and double fuel mileage. 3.50 gears will make the car a LOT more fun, but will make the car busier at expressway speeds.
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 13257 |
^^^ oh that's right!
n2fordwagons ![]() Senior Member ![]() ![]() Joined: 20-July-2013 Location: GA Status: Offline Points: 2170 |
Jeff
71 Torino Brougham |
Anyone know what compression on my 302 should be? Stock 79 bored .030 over.
Jeff
now this would be a nice addition to all that and would fit all under the hood and really wake that car up a bit!!!
![]() http://www.ebay.com/itm/TORQSTORM-SUPERCHARGER-SYSTEM-SMALL-BLOCK-FORD-302-351W-ARP-K-FD302-/272255574200?hash=item3f63b260b8:g:-GcAAOSwBahVfZJG&vxp=mtr |
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Online Points: 5233 |
'rebuilder' pistons usually over compensate for the increased bore diameter with an excessing capacity dish to prevent the rebuilt engine from getting into an octane requirement problem
if you're going to re-cam the engine using the existing bottom end, make sure you don't choose a cam that asks for more static compression ratio than you have, overall performance will suffer due to reduced cylinder pressure. in general performance cams assume that you will have better than stock static CR, you'll want to choose a cam that improves cylinder pressure. indicators will be short advertised and .050" duration numbers and low or no overlap at all the 'hotter' the cam the more static CR it wants
Any recommendations on ignition? Will my existing Duraspark II be sufficient? I found this post on HAMB, where a couple of folks actually recommended the Duraspark over HEI and others.
Jeff
papadeath ![]() Senior Member ![]() ![]() Joined: 08-December-2011 Location: Eagle Rock, CA Status: Offline Points: 498 |
Ok, I'm sorry this engine isn't anything classic (though I'm sure it will be), but I'm building a 2002 4.6L 2v mustang gt motor for a friend and its missing a lot of parts and I'm wondering if any of you have any resources having to do with all the parts needed, torque values, etc. That would be freaking awesome! Thx in advance! He has aluminum heads and cams and a Victor Jr intake instead of the factory intake and he's gonna be using the throttle body to feed it. Its got Manley forged pistons, forged crank and ibeam rods and roller rockers. Don't see any lifters or pushrods though, gak! No valve springs either, was thinking about some services. Think its gonna need valves as well, didn't see any. Its bored out to a 5.0 as well.
75 Ranchero in progress
04 Harley Deuce stage one kit 89 Toyota pickup modded 09 Scion XB (bought for the ol' lady) buy American! (sorry) skateboard 4 bicycles 1 scooter 2 dogs 2 stupid cats |
I have a Pertronix flamethrower III and it works flawlessly. I bought the 60K volt coil too, looks bad a**.
MrSmog ![]() Senior Member ![]() Joined: 21-January-2016 Location: Ky Status: Offline Points: 1314 |
I ran 2.5" duals with a summit version of the magnaflow mufflers, even with the 2.79 gears i could light the tire up from a dead punch for about 15 feet, now that I put 3.55's in (8" rear) i can light them up for much longer, cars is much more fun to drive around these Appalachian twisty roads and hills. I can cruise at 65 mph and the rpm's aren't too bad with the 225/70/14's On wet road though if i punch it at 50-60 the tire will break loose. this is in my 73 base 302/c4 car which is bone stock. I think 2.5" is fine for a 302, even one of these low comp smog era motors.
Past 1974 Ranchero GT Q code
Present 1973 Q code formal roof base model Torino with ralleye equpiment package and 4spd. |
4.6 isn't that the newer style motors they used in the early crown vic cop cars??? IIRC those were overhead cam...
4.6 is a MOD motor, no lifters, no pushrods ... cam followers
7T9_Tbird ![]() Senior Member ![]() ![]() Joined: 04-December-2017 Location: Athens, Alabama Status: Offline Points: 482 |
the Few things i know about the 4.6 SOHC motor;
1. The factory head bolts are torque-to-yield. You don't reuse the factory head bolts, you buy new ones, either factory or aftermarket. 2. the factory rods are not machined where they meet the caps, and vice-versa. They use what they call a "cracked powdered metal connecting rod", where the rods cap is snapped off during machining, making what is supposed to be a perfect mating surface between the rod and cap. If your reusing the rods, make sure they are marked for location in the motor and orientation to each other, 3. They use a crank-driven oil pump. 4. Be careful installing the spark plugs. Some heads use a collar that threads into the head, then the plug threads into the collar. older motors have been reported to fire stripped plugs and collars through the hood(not kidding-look it up). My dad has one in his '46 ford, and i have a 4.6 DOHC motor from a Mark VIII Lincoln on a stand, waiting for the right project. Good luck with it, it's a VERY complex piece of hardware.
John
original spark plugs were 2 piece and they separate leaving 1/2 in the head with no hex and the plug holes are only threaded 1/2 their depth so the threads are weak, plugs either seize and take out the threads or come loose and pull threads as they blow out several companies make repair inserts
Wow, thx for the info, this is exactly what I'm talking about, all the little side notes about stuff, it actually makes this build scarier. I know I can pull it off, though. The heads are brand new aluminum, and all the parts I'm using and will be acquiring are/will also be new. They are forged Ibeam rods btw. I did find something out from Manley in that there has to be .030 piston to wall clearance on their forged pistons due to expansion. When I got it (lucky dude that had me do this cause I'm so an*l about s**t being right, hehe), it had a little rust in a few of the cylinders and had several thousandths taken out and was afraid he couldn't use his new pistons but he was dangerously UNDERbored, if he'd had run it it would have seized. Thanksfor the wealth of info AGAIN! LOVE this site. Laterz, any other tips, sites super welcomed.
Oh, btw, I moved to Azusa, CA about 4 years ag, forgot to post it. This place is the pit of H*ll, super hot all year around. I live in one of the 4 BACKHOUSES down a driveway, never seen THAT before. Well, that's efficient use of your real estate, eh? Apparently I'm the only one smart enough to put a tarp up over my driveway so I can work outside (ol' lady wont let me build s**t in the living room, whats wrong with women???).
Forgot to ask, any preferences of brands for a good set of gaskets? I need all of them. 2002 2V 4.6L Mustang GT
Fel-Pro, always.
John
if they're not already done, consider doing the spark plug inserts as a preventive measure
Absolutely.
John
closetwino ![]() New Member ![]() ![]() Joined: 28-November-2020 Location: SoCal Status: Offline Points: 10 |
I feel that this thread has been hijacked by 4.6......
68 Ford Ranchero 302 Auto
Page <12 |
Tweet
