  New Posts New Posts RSS Feed - Anyone done a 5spd Tremec Swap
Gold73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gold73 Quote  Post ReplyReply Direct Link To This Post Topic: Anyone done a 5spd Tremec Swap
    Posted: 18-September-2019 at 11:46AM
Has anyone here converted a floor shift automatic to a 5 speed Tremec TKO manual with a hydraulic clutch behind a 351 Cleveland? If so I would like to visit with you. I have talked to the fellas at Modern Driveline and they have the components minus the crossmember. The only hiccup is having to change the brake booster to a hydro boost because of the large booster. Sans the questions I have in the conversion. All replies will be greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2019 at 1:56PM
andy eliteman 76 did on his car not sure if he's updated his thread that far yet???it's on here somewhere titled barnfind...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 19-September-2019 at 7:31PM
i don't see why you couldn't swap the large single diaphragm booster for a small dual diaphragm unit?
1971 460 Torino used a dual diaphragm, CARDONE 5473200
no idea if it's a direct swap or do-able at all though. rodders use all sorts of small boosters to get the job done, GM units, the GEO booster is popular
but again no idea what the swap would entail or if the GEO master is suitable.... i haven't done any research into it
Edited by Rockatansky - 19-September-2019 at 7:41PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-September-2019 at 11:57AM
Todd (Aquartlow) has done the hydroboost conversion, so he can probably help you out with the details on that if you choose to go that route.
Otherwise, I think Rock's idea of finding a smaller booster would work.
BadHabit351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2020 at 3:23AM
I have a TKO in my car. It was a column shift C-6. I had a floor shift parts car that I swapped the steering column.
My car: 393C (stroker), TKO 5 speed.
1973/72 Gran Torino Sport
1971 Torino GT convertilble
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 15-October-2020 at 12:38AM
Nice idea, and a crossmember can easily be fabricated.
JT, USAF Ret./Architect
1971 Ford F100 "Lizzy"
1971 Cougar XR7 "Kitty"
1984 Chevy Silverado "Sylvia"
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 15-October-2020 at 12:51AM
Didnt't have to. The C-6 crossmember fit with some "minor" adjustments (elongated mount holes). I even used a C-6 transmission mount...put my pinion angle DOB (dead on balls).
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 15-October-2020 at 12:57AM
If you did this swap and you have pics, please share them.  I know others would be very interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 15-October-2020 at 12:57AM
I too did the hydroboost conversion. I was unable to find a booster small enough to give me the room I was looking for. Added advantage; hydroboost seems to send more pressure to the brakes. Being as mine was from a 78 Lincoln Mark V; it was darn near bolt up. I did have custom hoses fabricated.
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 15-October-2020 at 12:59AM
I'll have to dig through what I have left. I ran over my phone with a forklift a couple years back.
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
302ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 302ford Quote  Post ReplyReply Direct Link To This Post Posted: 16-October-2020 at 8:01AM
I did my tremec tko swap about 8 years ago. I used the pedal/ brake booster cable clutch setup out of a foxbody mustang. Shifter placement came very close to factory hump, and crossmember required minor modification and driveshaft needed to be shortened.
79 LTD II 408/TKO/3.7's
11.78 117.3mph. drag radials
