Anyone knowlegable wit the 300ci? |
lynchster ![]() Senior Member ![]() ![]() Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 1914 |
![]() ![]() ![]() ![]() ![]() Posted: 17-July-2016 at 6:37PM |
I'd like to know what, if any differences there are in the blocks between the 72-86 300 and the 87-95 300. My brother in law has a rebuilt one pulled out of an 80's F150 and I was wondering why the block wouldn't be compatible with the newer generation. Knock sensor fitting maybe?
Edited by lynchster - 17-July-2016 at 6:37PM |
Big Bird ![]() Senior Member ![]() ![]() Joined: 25-August-2013 Location: New York Status: Offline Points: 3862 |
I think it's when they went to EFI, so the newer engines (may) not have a fuel pump mounting provisions.
As far as I remember, no roller cam, so that's not the issue.
Everything I can find points to the fuel pump issue.
Also found this: More entertaining than helpful, but...
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 13029 |
do the newer ones have a distributor location? if not it may need to have a crank triggered system
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 5120 |
mtburger ![]() Senior Member ![]() ![]() Joined: 24-November-2008 Location: Abington, MA Status: Offline Points: 317 |
I have seen some cool stuff done with these.
I will look when I get home, but I think the original Ford Off Highway Parts book has a section on the Ford Six's. The link below is to a well documented 300 six, using 3 cut up Boss 302 (Cleveland) heads welded together to make a Boss 300 inline six. Super cool, a bit crazy, but cool nonetheless. https://fordsix.com//viewtopic.php?t=33048 Mike H. ![]() Edited by mtburger - 20-July-2016 at 4:39AM |
7T9_Tbird ![]() Senior Member ![]() ![]() Joined: 04-December-2017 Location: Athens, Alabama Status: Offline Points: 482 |
I pulled a head off of a '87 Econoline van (FI motor) years ago to replace the warped head on my F150. I know it has a smaller, heart-shaped combustion chamber. I wound up using the whole top of the motor, minus the FI intake. I used the split exhaust manifolds and pipes up to the cats for a true dual exhaust setup, a Offy 4-bbl intake and Clifford cam. That thing would roll out of the gate in 1st like nobody's business. GREAT torque engines.
John
interesting this came up, 2 mins later another search brings me to the Ford 6 site
for 2bbl cfm ratings |
hogfiddles ![]() Senior Member ![]() ![]() Joined: 19-September-2016 Location: Central NY Status: Offline Points: 701 |
My first truck was an '80 f250 with a 300 straight six. All the power I needed, and it couldn't be killed. 1st gear was a granny gear and it was impossible to stall it. I could walk faster. It was really funny on the days I'd get stuck in snow.......I could open the door and push, and when the truck finally gained traction and 'took off', I could just hop back in.
Those were the days........ The only issue I ever had, was the engine's rear oil seal had worn out, so it dripped at the back. I often thought about about getting the Offy intake so i could put a 4bbl on it, bt never committed. Edited by hogfiddles - 12-October-2018 at 3:19AM |
1969 Torino GT - M code numerous mid-80's Yamaha XJ-Series (10 trophies and counting) |
Tweet
