Forum Home Forum Home > Engine Specific Forum > Six Cylinder Forum
  New Posts New Posts RSS Feed - Anyone knowlegable wit the 300ci?
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Topic: Anyone knowlegable wit the 300ci?
    Posted: 17-July-2016 at 6:37PM
I'd like to know what, if any differences there are in the blocks between the 72-86 300 and the 87-95 300. My brother in law has a rebuilt one pulled out of an 80's F150 and I was wondering why the block wouldn't be compatible with the newer generation.
Knock sensor fitting maybe?
Edited by lynchster - 17-July-2016 at 6:37PM
91 F-150
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 18-July-2016 at 11:31AM
I think it's when they went to EFI, so the newer engines (may) not have a fuel pump mounting provisions.
As far as I remember, no roller cam, so that's not the issue.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 18-July-2016 at 3:45PM
Everything I can find points to the fuel pump issue.
Also found this:
More entertaining than helpful, but...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-July-2016 at 5:20PM
do the newer ones have a distributor location? if not it may need to have a crank triggered system
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 20-July-2016 at 3:20AM
mtburger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtburger Quote  Post ReplyReply Direct Link To This Post Posted: 20-July-2016 at 4:39AM
I have seen some cool stuff done with these.
I will look when I get home, but I think the original Ford Off Highway Parts book has a section on the Ford Six's.
The link below is to a well documented 300 six, using 3 cut up Boss 302 (Cleveland) heads welded together to make a Boss 300 inline six.
Super cool, a bit crazy, but cool nonetheless.
https://fordsix.com//viewtopic.php?t=33048
Mike H.
Edited by mtburger - 20-July-2016 at 4:39AM
7T9_Tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7T9_Tbird Quote  Post ReplyReply Direct Link To This Post Posted: 22-December-2017 at 8:10AM
I pulled a head off of a '87 Econoline van (FI motor) years ago to replace the warped head on my F150.  I know it has a smaller, heart-shaped combustion chamber. I wound up using the whole top of the motor, minus the FI intake.  I used the split exhaust manifolds and pipes up to the cats for a true dual exhaust setup, a Offy 4-bbl intake and Clifford cam.  That thing would roll out of the gate in 1st like nobody's business.  GREAT torque engines.
John
79 Thunderbird Heritage
79 Thunderbird Town Landau
02 Ram 1500 Sport Quad Cab
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 22-December-2017 at 11:19AM
interesting this came up, 2 mins later another search brings me to the Ford 6 site
for 2bbl cfm ratings
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 12-October-2018 at 3:18AM
My first truck was an '80 f250 with a 300 straight six. All the power I needed, and it couldn't be killed. 1st gear was a granny gear and it was impossible to stall it. I could walk faster. It was really funny on the days I'd get stuck in snow.......I could open the door and push, and when the truck finally gained traction and 'took off', I could just hop back in.
Those were the days........
The only issue I ever had, was the engine's rear oil seal had worn out, so it dripped at the back. I often thought about about getting the Offy intake so i could put a 4bbl on it, bt never committed.
Edited by hogfiddles - 12-October-2018 at 3:19AM
This page was generated in 0.055 seconds.
