  New Posts New Posts RSS Feed - Anyone used the Fatman Fabrications drop spindles?
Hey Z View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hey Z Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2015 at 2:37AM
Yes we did get them to work with the wildwood brakes.  I still need to get the car aligned and once I do I will report back to you on how they are.  The wheels are now farther inside, but the camber is way off right now so it doesn't drive well.  Once I get the camber and alignment cleaned up I will let you know my impressions and try to get the part number too.
My '72 restomod My Link
cggrob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cggrob Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2015 at 12:45PM
I am using the 2" drop Fatman spindles for the 1972 Torino.  You need to measure lower ball joint dimensions where it goes through the spindle - Fatman claims there were 3 different dimensions offered on the 1972.  They fit fine except they are not as thick as the original spindle and therefore do not go all of the way down on the ball joint  - but they do seat correctly. I also used the 13" WilWood brake set-up.  Car is still under construction and I don't get to the shop much. 2" drop spindle with the 1999 Crown Vic PI 710 lb/inch springs and 275/35/20 tires on the front.  Also a 2" drop at the back on custom wound coils with 315/35/20 tires.  John Haney at Blue Oval in McDonough, GA is doing the work - fresh paint in the pics!
Billy C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy C Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2015 at 8:25PM
Are there even detailed pictures of this mystery upright/spindle anywhere?
Originally posted by cggrob cggrob wrote:
....275/35/20 tires on the front.  Also a 2" drop at the back on custom wound coils with 315/35/20 tires.
275s in front and 315s in rear! 'nuff said. Thumbs Up
Edited by Billy C - 22-January-2015 at 8:29PM
-Billy Conturo
Post Options Post Options   Thanks (0) Thanks(0)   Quote cggrob Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2015 at 4:49AM
I can get detailed pics of the FATMAN spindles for everyone with them mounted on the car in another 2 weeks or so.  Also, I had to add some thread to the inner tie rod ends to bring the toe in because of where the steering arms are welded to the spindle.
Once suspension is sorted out I will be moving up to a 295/35/20 & 335/30/20 combo.  The front tires are no problem but to fit the rears the frame is scalloped out and the wheelhouse moved in a couple of inches.  Also using the SPOHN upper and lower control arms - lowers are required for clearance as well, as their tubes are narrower than the stock stamped control arm.  It's all tight but it fits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2015 at 6:49AM
That is beautiful! You are the first person I've seen that has fit 20's under the front and been able to tuck them just right.
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2015 at 7:26AM
Ditto, I just realized that those were 20" wheels. Keep us updated with that. I like bigger wheels and tires, but the 16 or 17's are tough to find a decent tire that would look right to me.
73 Ranchero with a 72 Sport front end, parked since 1990
91 Lincoln Mark VII SE, OBDII 347/4R70W
98 Mercury Mountaineer
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2015 at 9:31AM
Come on now...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2015 at 10:17AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote cggrob Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2015 at 12:25PM
UH?......my front wheels can actually turn?
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2015 at 12:33PM
My ride ain't no trailer queen! Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote cggrob Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2015 at 12:36PM
LOL!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2015 at 12:53PM
LOL!!!
Sorry, I should have said this before. REAL NICE ride you have there, sounds and looks like the updated parts/installation were great choices. I realize it looks like my Ranchero can only go in straight lines LOL,  but the tires don't hit or even rub(gotta love the 77-79 wheelwell flare and the Moog 80100 854 in lb front spring rate). I am not running nowhere near as wide a tire as you either, only 245's but the big block keeps the fronts planted nicely Wink. Post more pics of your cool ride and the mods done. Todd
Edited by aquartlow - 23-January-2015 at 12:55PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote cggrob Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2015 at 1:51PM
LOL!!!
No offense taken...all in good fun!  Your Ranchero is nice...even if half of the car is missing!
When this is done I will do a write-up.  I do not really have any build pics - I am almost afraid to keep track of it all!
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2015 at 2:31PM
LOL!!!
Quote-"I am almost afraid to keep track of it all!"  Oh, so you're married. LOL
 Thank you for the positive comment. Post pics when available.
Sorry to have hijacked this thread....my firesuit is on. Wink
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 26-January-2018 at 2:53PM
Bringing this back from the dead. Any pics of the spindles/wilwood installed? Part numbers?
I checked online and it seems you have to run granada rotors ad camaro calipers to make everything fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2018 at 1:20PM
Seems weird to me that it's listed for 1965-73, when 1972-73 has a completely different suspension. But it seems two people have installed them.  I'd be interested in seeing some pics too just to know they actually exist.
Edited by 72FordGTS - 27-January-2018 at 1:20PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 28-January-2018 at 4:50AM
Fatman does make drop spindles for the Fulsize Ford and Thunderbird thru 78-79. It could be that they are sending those out when 73 torinos are requested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy C Quote  Post ReplyReply Direct Link To This Post Posted: 28-January-2018 at 7:21AM
I'd still like to see this setup on intermediate chassis as well. Not really worried about the Wilwood part but the spindle is a real mystery at this point.
-Billy Conturo
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 29-January-2018 at 12:44AM
The company pure vision designs in california used fatman fabrication drop spindles on a '72 gran torino. They modified the front control arms and installed Custom adjustable QA1 coilovers. Unfortunately there are no good pictures of the spindles before they installed them on the car.
Edited by dave302 - 29-January-2018 at 1:22AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 29-January-2018 at 12:48AM
There are more pictures of the spindles as you scroll down towards the bottom of the page.
Edited by dave302 - 29-January-2018 at 12:54AM
