  New Posts New Posts RSS Feed - AOD trans into a '70/'71 Torino/Montego
M-code Montego View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M-code Montego Quote  Post ReplyReply Direct Link To This Post Topic: AOD trans into a '70/'71 Torino/Montego
    Posted: 05-July-2015 at 5:33PM
I'm considering swapping the C-6 for an AOD in my '71 Montego. Have any of you done this swap? Which trans is simpler, a hydraulic or an AOD-E which will require an ECU. What about the trans crossmember? can I use the stock one or will I need a custom one? I know the drive shaft will need to be modified. My goal is better mileage and cruiseability. Any advise would be appreciated.  Oh, the engine is a 4 barrel 351 Cleveland and a 3.25 rear. Any advice is appreciated.
1. 1971 Montego parts car, but it still runs!
2. 1971 Montego. Numbers matching 4V Cleveland, C6, 9 inch rear 3.25 Trac-lok(project car)
3. 2003 Crown Victoria P71 ,Daily driver
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2015 at 5:50PM
i swapped my FMX for an 84 AOD in my 74 torino, 351W. cross member and mount was the same, i did trim a little off the front lip of the cross member so i could drop the pan if needed, and swapped the front drive shaft yokes, using the AOD yoke on the torino driveline. added a floor shifter. and used a lokar kick down cable kit. fairly bolt in swap, but not sure about the cleveland
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2015 at 7:46AM
If it bolts to a Windsor, it will bolt to a Cleveland. Flexplate is going to be a question. AOD uses the same flexplate as FMX, don't know if it's the same as C6
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2015 at 3:31PM
i thought they bolt the same as a windsor, but i wasn't 100%. but is the bolt pattern on the crank the same as a windsor???IDK, if it is then grab the flexplate too with the tranny. i know they are mostly the same between the 302 and the 351W only difference there is the converter drain plug is on opposite sides of the converter stud
