  New Posts New Posts RSS Feed - are you looking to build your 400?
gnrlee01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gnrlee01 Quote  Post ReplyReply Direct Link To This Post Topic: are you looking to build your 400?
    Posted: 31-July-2016 at 7:27PM
i have a completely brand new high performance (o.566 lift) cam set with valve springs, roller rockers, roller lifters, timing set, high volume oil pump, 2 sets of push rods all never opened. i also have a couple of used edelbrock 4 barrel intakesone cleaned and painted, the other one not painted.
i bought the valve train set as a complete package from summit with the intent on putting them into my 400 from another car, but i no longer have that car and i can not use them. all together i paid 1000 dollars for the set from summit and 150 dollars per each intake. i also have a small 390 cfm 4 barrel carb that i paid 200 bucks for.
if any of these can help you, let me know..shoot me an offer. i cant use them, so i am in need of selling them now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gnrlee01 Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2016 at 12:54PM
i ordered this kit form summit last year when i was thinking of molesting my 76 torino survivor car that had a 351M. i was going to make it into a 400, but since than i have traded to a 460 car and i can no longer use these parts if anyone can use them, let me know.
i have 2 seperate 4 barrel intakes for the 351M-400 one painted black, and the other not. i also have a small 390 cfm 4 barrel carburetor.
i have a high volume melling oil pump that i purchased to go along with this kit as well as an extra set of pushrods, because i wasnt sure if i would need them or not.
it also has a new set of valve springs made for the use of this cam and a double roller timing chain set.
the kit number is "comp cams k32-421-8"
the actual cam box says 32-421-8 cam specs are int 270. exh 270. dur @ 0.50: 215 215 lobe sep 110.0 valve lift 0.566 0.566
sn# wl3719-15
if i have to throw a number first, i would love to break even and get what i paid for, for them which was a little over a grand for everything in the kit, including the oil pump and additional set of push rods. but i also realize that for me to break even, it wouldnt be any different than if you went to summit and ordered the same set yourself, so i know that is somewhat unlikely on my part. so lets make a deal...i would hate for these to go to waste, since im not going to use them.
steve.
