  New Posts New Posts RSS Feed - Auxiliary Tranmission Cooler
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Topic: Auxiliary Tranmission Cooler
    Posted: 07-October-2018 at 2:44PM
I am wondering how many here have added an auxiliary transmission cooler?  I am thinking of adding one to my car.  I am just wondering what you guys are running?  If you're willing, please share some pics of your setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 07-October-2018 at 2:54PM
i used the factory mounted A/C condenser in the front of the radiator,
then i ran it back through the radiator to establish & maintain a steady operating temp.
blow the excess heat off & stabilize ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 08-October-2018 at 7:10AM
You used a A/C condenser as a trans cooler?  I didn't know you could do that.  Have any pics?
I have always run it back through the rad afterwards too when I have installed coolers in the past.  I figure it's also helpful with the colder weather we get up here.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 09-October-2018 at 6:21AM
no pics, not sure i still have the coil but i might, buried in the pile?
i remember the coil is a 'double pass', it spits the flow and runs 2 parallel circuits from top to bottom then they rejoin together. i just cut the tube between where they rejoin and the A/C fitting for a simple hose on tube connection with double clamps. does this pic showing the magnetic inline filter count?
Edited by Rockatansky - 09-October-2018 at 6:22AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-October-2018 at 1:21PM
lol i used one once years ago for a fuel cooler Wink had one car that wanted to vaperlock on warm days it did the trick Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 12-October-2018 at 1:57PM
Thanks for the pics Rock.  I will probably install something, just want it to look clean and somewhat factory like.  I have installed stacked plate coolers in the past with the cheesy metal brackets they come with.  They worked fine on a daily driver/work vehicle, but I want something nicer for my Torino.
