  New Posts New Posts RSS Feed - Axle codes
Axle codes
Lizer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lizer Quote  Post ReplyReply Direct Link To This Post Topic: Axle codes
    Posted: 04-January-2020 at 6:01AM
I'm sure this has been posted somewhere, but I'm looking for an axle code decoder. Specifically, my axle code is 1.
2.50?
67 Mustang (5.0)
69 Mach 1 428 SCJ Drag Pack
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2020 at 7:24AM
this example shows a door tag code '2' and states 3.00:1 gear in the text
my first guess would be that it's a 2.75:1 gear
for whatever reason 1978 door tag axle codes are pretty hard to find
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2020 at 8:41AM
i looked in my 74 manual and it starts at a "2" no #1 shown Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2020 at 2:41PM
same with the 1976 decoder i found online
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2020 at 3:15PM
We have tons of info on the site, but not as much for the 77 to 79 cars. If you check this link:
we have all the info year by year including door data plate. The data plate info isn't there for 77 to 79 but 1976 shows a 2 is an open 2.75:1 diff.  The 1978 info shows only a 2.50:1 and a 2.75:1 were the only ratios available.
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2020 at 4:05PM
hmm, since you have the body off... look at the front of the 3rd member, there should be a tag on one of the bolts... about the 10'clock position... it will have the ratio on it Wink since you know the history since new chances are its still on there?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 05-January-2020 at 3:53AM
and if the tag is not present from Day 1 there's a reason, anything can be in there
there's always the old fashioned way ...
trans in Neutral, jack 1 rear tire off the ground
can you turn the tire very easily? if yes it's an open differential
if No it may be a Trac-Loc and you'll need to jack both rear tires off the ground
rotate a tire until the valve stem is at 6:00 (bottom) or 12:00 (top) whichever is your preference
now mark the driveshaft in such a way that you can determine when it has completed 1 full turn,
a simple horizontal line 1/2 way between top & bottom will do
now rotate the tire slowly counting how many rotations the driveshaft makes,
stop the tire after 1 complete rotation
how many rotations did the driveshaft make, and how much of a partial rotation?
did it stop exactly on a complete rotation or is it over or under 1/2? how much?
for a Trac-Loc or other Limited Slip that holds the rear tires together solidly (not totally whipped out) the revolutions you counted are the gear ratio
for open diff's or whipped out LS units with only 1 tire off the ground divide your driveshaft revolutions by 2 to find your ratio
the last remainder of an incomplete revolution is the decimal fraction of the ratio so try to be accurate in estimating the partial revolution
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lizer Quote  Post ReplyReply Direct Link To This Post Posted: 05-January-2020 at 4:23AM
The body is still sitting on this car (my car), it's the donor body that is off the car (though that body was bolted  back to the frame to transport it from Indiana).
My car is sitting out in the equipment shed. As far as I know, the only time anything has been done with the third member is when me and a buddy removed it around '98 to replace the gasket. I will have to check the tag, it should still be there.
Otherwise yes, the next time I had it on concrete I could also do the old 'count the driveshaft rotations' trick. I'm sure it probably is a 2.50 in there, the car ran about 2500 rpm on the interstate going 70 mph.
I will rebuild the rear end to 3.55 anyways, but this is really more of an exercise in decoding everything since it's original, and learning some more about the history of the car I didn't know.
67 Mustang (5.0)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 05-January-2020 at 11:48AM
I suspect your are correct, that it's likely a 2.50:1 rear gear.  Rock's method would work to check the ratio, or if you pull the third member at some point, count the teeth and do the math.
If you have a tag on the diff, post it here and I will see if I can decode it for you.
When you upgrade, don't junk the 2.50 or 2.75 gears.  They are no longer available new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 08-January-2020 at 1:08PM
is it an "S" code car?
400 usually had the 2.5 axle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-January-2020 at 4:46PM
 i have an "S" code 400 parts car and the door tag says it has a 3.00 in it ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 09-January-2020 at 3:25PM
My S code has a 2.75 tag on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 12-January-2020 at 3:09AM
On the later cars (77-79) 2.5 was standard axle for the 400.
Some Brainiac at ford said "Let's give 'em the big engine, a C6, and then add 2.5 gears to take away any semblance of performance"
Apparently a practical joke on their buyers.
Wanna see a 78 T-bird with a 400 really wake up? Swap in a 3.5 chunk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lizer Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2020 at 5:01PM
This all reminds me I still need to go check that tag.
Oh! Were these 8" or 9" rear ends?
67 Mustang (5.0)
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2020 at 6:02PM
not sure on the later cars but 72-76 had mostly 9" but some had 8"
several ways to tell......  the back of the housing is curved with just 2 dimples it's an 8", if it has an extended area for the ring gear on the back it's a 9"
also looking at the front 3rd member 8" has more of a grid pattern on the reinforcing webbing than the 9"
also if you can remove all the nuts with a socket and extension it's an 8" if 1 or 2 are behind the pinion bearing part of the housing it's a 9"Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 14-January-2020 at 10:22AM
Shouldn't be any 8" rears after 72...
But, Ford.
So never say never.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-January-2020 at 4:50PM
that 74 4dr i parted had an 8"
