  New Posts New Posts RSS Feed - back pressure,needed or not
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 26-July-2017 at 6:07PM
Originally posted by fordpower fordpower wrote:
... because 15yrs ago they could not legally remove them.
still can't AFAIK?
but yeah hot in / cold out = Dead
street zoomies ... the print says zoomie, remote mount w/extension Hahaha
Y'all ain't got no zoomies?
Edited by Rockatansky - 26-July-2017 at 6:08PM
Don V. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 1:33AM
still can't AFAIK?
I remember in the early days of CATS leaded gas was still available next to the unleaded. A lot of people would save the extra 2 or 3 cents more that unleaded cost and put leaded gas in their CAT vehicles. It wasn't long before those loose platinum coated beads turned into a solid brick clogging the exhaust.
Rock, I'm not sure what you're getting at with, "The print says. . .," but your link is defines what I grew up understanding what zoomies are. If your local cruise night is the Holly Reunion fwiw I'm impressed. Pretty short cruise though isn't it?
Edited by Don V. - 27-July-2017 at 12:38PM
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 1:58AM
OK so cost wise decided replace cats. found two that are sappose to be direct fit Walker or magnaflow .
can't use because ny now requires calf. specs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 2:22AM
Is NY a state that requires inspections and the window sticker from passing the inspection? If so, your requirements are written for you. You may have to put mufflers on to be legal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 3:58AM
yes and no only needs to pass safety because of age. Yet legal garage can not put on cats not Cal certified and I can not weld that good. Would have to find someone in Pa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 5:54AM
does your emission tag state California Emissions?
only years specified (skip 1995 for some reason) and cars equipped with CA emissions
i'd go talk to someone else before you get into a twister next inspection
so what is your set-up? you use the plural 'cats' as in multiple so i'll assume 2, just down pipes off cast iron manifolds to factory cats ... anything after the cats?
and more importantly, what caused them to fail? is the engine using oil recently?
what year is it, what carb/injector/throttle body set-up?
any recent changes on the top end fuel delivery?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 7:03AM
Yes 15 yrs ago they just came off of cats to duels with what they called an h pipe. Sound was nice so did no mufflers. NY now requires cal cats. When I tried to order ones from on line state not adv in NY or cal? These are org.to car.Will probably just go with mufflers depending on cost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 9:20AM
For 1979, no requirement for Cali Cats, that's only for years NYS required Cali emissions.
Cats are not checked in most of NY, safety only, no emissions inspection for pre-1984.
Shops can't pull off WORKING cats, but under no obligation to replace a defective cat.
So, for instance, your entire exhaust were to fall (off for some strange, inexplicable reason).
You don't need to replace the cats, and it doesn't need to meet Commiefornia emissions, or any emissions really.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 9:32AM
Originally posted by Don V. Don V. wrote:
"Misuse of laws/expansion beyond mandate should be a criminal offense, punishable by a swift kick in the crotch on Primetime national TV, administered by the kicker from the previous year's Super Bowl champions. Big smile"
Is this an updated version of "Get off my lawn," "Grumpy old man," or both?
It MAY be in the tradition of "Get off my lawn" and being a grumpy old man, but who could resist seeing politicians getting kicked in the family jewels on national T.V.? By a professional kicker?
stanman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanman Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 10:26AM
If your cats were to fall off and something, say a steel bar, found its' way inside them and knocked all the guts out would that be your fault.? Pretty sure not...   Ermm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 10:50AM
Say the Y pipe or H pipe came loose and drug-crazed vandals were to poke a bar thru the catalyst and crumble it, knock out all the guts and stole them....
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanman Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 12:30PM
Exactly! You're only human! How could you forsee or prevent that? You couldn't!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 12:43PM
Can't argue with that. First impression was something a little more personal though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 12:47PM
It's been a long time since this was a topic. At some point they learned it was quicker and quieter to just take the whole car.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 12:50PM
Mufflers should be less then CATS or even a CAT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 2:08PM
advance auto $70 ea & 20% off, actually not too bad. I've spent more on mufflers Embarrassed
the discount for the 'farm use' iron pipe mishap doesn't look bad either
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2017 at 2:22PM
No doubt but that same discount import company probably has $25 mufflers to go with their $70 dollar CAT. Nothing wrong with either.
Edited by Don V. - 27-July-2017 at 2:23PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 22-August-2017 at 10:16AM
Well garage said try some of that cat cleaner. Went on a little cruse Sunday. Drove to Norwich car museum Put some of that stuff in and drove home 125 mi over all. Well two things I noticed. It is running hotter and sounds louder. Going to have a temp check and try another can of crap.
