  New Posts New Posts RSS Feed - Back up lights
Back up lights
Dstitt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dstitt68 Quote  Post ReplyReply Direct Link To This Post Topic: Back up lights
    Posted: 28-April-2020 at 11:33PM
1972 torino sport  console shift  c6 transmission  with seatbelts light buzzer back up lights were working .  My son went to back the car out the other day and a notice that they weren't I check power nothing to bulb,   ground is good when i jump12 volts to connector thumbs light . I found the back up neutral switch but not sure how to check it or what the wiring set up is . Also fuse is good power on both sides . HELP PLEASE  looking for a wiring diagram for 1972 sport with floor/console  shift
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 30-April-2020 at 1:20AM
I'm hoping some guys chime in here, because my back up lights have never worked on my wagon and I have not really messed with it because I'm not sure where to start other than checking the bulbs. Maybe someone can explain in further detail the wiring schematic and how to go about correcting the problem.
Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 30-April-2020 at 1:16PM
Welcome to the forum.  If you have no power to the reverse lights, check that your reverse switch is getting power and that the switch is working properly.  See this screenshot from the wiring diagram below. You should be able to follow the diagram to check the wiring and switch.
We also have all kinds of wiring diagrams to download here:
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-April-2020 at 8:06PM
ok, taking a quick look at the diagram... white with a purple stripe is the fused power supply to the switch, with the key on check for power there! if no power check the fuse ( i think it's labeled back up) if theres power on both sides of that fuse it's good, post where you have power at those 3 points and i can tell further where to check to narrow it downWink
This page was generated in 0.145 seconds.
