Forum Home Forum Home > General Discussion > How-To Articles
  New Posts New Posts RSS Feed - Ball joints
Ball joints
Will View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote Will Quote  Post ReplyReply Direct Link To This Post Topic: Ball joints
    Posted: 01-January-2018 at 4:30AM
I have two 72 torino frames one has front pressed in ball joints the other has bolt in ball joints just asking besides that what else is different so I don't mismatch anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-January-2018 at 5:06AM
factory originals are generally riveted in, bolted ones usually are replacements
74 CORVETTE COUPE CUSTOM
Will View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote Will Quote  Post ReplyReply Direct Link To This Post Posted: 01-January-2018 at 5:19AM
One is just pressed in no holes for the bolts now these are lower ones the other frame the lower has rivets
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-January-2018 at 5:33AM
hmm. yeah some things are unique to 72's
 i'd keep all the stuff together I.E riveted I.E. pressed in
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 01-January-2018 at 7:11AM
Welcome to the forum!!  Please introduce yourself by making a post in the Welcome Mat area.
1972 cars, generally early build cars, had the lower ball joints riveted in place.  The later 1972 cars and newer had the pressed in lower ball joints (lower).  The lower arms are different because of this, but other wise should interchanged frame to frame.
The upper arms were also changed in March of 1972, using different cross shafts and different sized bushings.  But again they can be swapped from frame to frame if you need to do so.  I agree with John though, keep all the same stuff together.
