Bearing issue ? |
Rivercrest
Member Joined: 07-December-2019 Location: Manitoba Canada Status: Offline Points: 175 |
Posted: 07-December-2019 at 5:47AM |
Hi to all, what a great forum to join. I am about to work on rebuilding / replacing a 351C engine, vintage 1974, that has a noise that reminds me / sounds like a squealing bearing. The engine runs, compression is reasonable good on all cylinders but with this noise I am afraid it won't run much longer. Fair to say the engine does not run very smooth . My mechanic's stethoscope tells me the squeal is at the back of the engine. When just turning the engine over (coil unplugged) there is no squeal. Shifting the C6 transmission into any gear does not stop the squeal either. looking for anyone's thoughts on if it could be a transmission issue and not something like a crank bearing.. Thanks to everyone.
Welcome aboard, feel free to introduce yourself in the Welcome Mat too. Do you have a video of the sound? Have you checked the oil pressure on the engine? I have never heard an engine bearing squeal.
really hard to say... usually if a bearing spins it with squeal for a second then pressure goes way up then down to nothing
it could be a loose bolt in the bellhousing or the plate bent rubbing the flexplate??? i'd check for a vacuum leak that could make a noise and would make it run crappy too... |
transmission pump whine?
^^^ i thought about that too
you just don't hear a good trans pump whine any more .... reminds me of my 72 chop top, yup chopped off the top Roadster Baby! it had a distinct whine, sounded like it was doing a Batmobile impression, turbines ya know
well when ya can't afford a blower, ya do the best ya can
keep them guessing you want noise? Oh wait i got this thing hangin out too |
hmm ...1 pair aces high, nice, but 3 of a kind beats a pair
Rivercrest
Well, when running ( rough ) I do show oil pressure on the factory gauges, who know if the gauge is actually reading variable pressure or if the sending unit is just on/off. So, further investigation shows only 2 quarts of oil in the pan and 1 quart (maybe) in the filter. I am sure that didn't help. Either way I am still going to pull the motor and tranny if for no other reason just to do a thorough clean up of both because the oil pan gasket is leaking everywhere and has blown oil all over the place.......no wonder the underside has no rust. LOL
Rivercrest
BTW, I will post a picture or two once I learn how.
if you have the GT Sport gauges it should have the ability to read varying pressure with the large sending unit. but there are several different calibrations of sending units so if it's ever been replaced chances are it can be inaccurate to the gauge scale ---------------------------- are you kidding me? 3 little pink carbs don't beat 2 660 center squirters! 351-8V Baby!
Rivercrest
Well, a few more days and I'll have the engine on the workbench. Then I'll start disassembly. Should be interesting..
3x 500=1,500 and they're peach! not pink |
gather as much intel as you can before pulling the coil wire off ... mechanical oil psi, cylinder psi / compression test, save the spark plugs in order for post mortem diagnostic etc etc ------------------------- it takes a secure man to run peach carbs i don't care what anybody says and not judging .... but they're 500 each really? i didn't know if they were 1bbls or 2bbls time to up my game i guess, i'm not sit'n by while i get beat by peach carbs! who's got a Big Foot Alan Root motor layin around? Edited by Rockatansky - 10-December-2019 at 6:36PM |
IIRC they are 500cfm? the throttle plate is at least the size of a silver dollar or bigger... they're rochester 1 bbl's
Rivercrest
Well, the plan is to pull the motor and tranny out as one assembly, wanting to check the relationship and connection between the two as a source for the noise. Today I spent 1/2 the day getting out the tranny cross member. As mentioned in previous threads, what a job it was. So stupid to have the x member sitting on top of the frame brackets. After I removed all the bolts, I attached a come-a-long between the rear axle and the driver's side and another come-a-long between the front coil spring and pass. side of the crossmember and after jacking up the tranny I was able to twist out the cross member.......project engine rebuild is continuing tomorrow.
once you jacked the tranny up did you remove the mount?, then you should have plenty of room to lift the crossmember up and off the brackets
Rivercrest
so much grease and oil under there, but yes all is well.
i wonder if you'll find a broken / cracked flexplate?
Rivercrest
So today I found totally fried bearing inserts on cylinders 4 & 8.
not good!
Were you also missing nylon off the timing gears? |
Rivercrest
Gears are all steel so I now know they have been previously replaced
handsofstone
Every old Ford engine I have had with lots of miles developed lower end noise mostly due to not caring about changing the oil religiously and just adding a quart or so every week and a new filter never. Eventually it catches up and bye bye long block.
Looking forward to pics for sure. The only positive from oil leaks is definitely the rustproofing you get at bo cost. Haha
Rivercrest
I've continued this topic here : 1972-1976 Ford and Mercury (18 Viewing)
Technical discussion for 1972-1976 Ford and Mercury Edited by 72FordGTS - 01-February-2020 at 9:55AM |
Bob
1974 Cougar XR7 with a 72 351C |
