  New Posts New Posts RSS Feed - bell housing
bell housing
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: bell housing
    Posted: 17-March-2017 at 8:53AM
Looking for bell housing for 302 for my c4 trans.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 17-March-2017 at 11:15AM
be careful, there's like 87 different variants
Edited by Rockatansky - 17-March-2017 at 11:29AM
75GranMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 17-March-2017 at 11:48AM
Exactly, Not that you can't make any one of them work.it's sure easier to get the correct one.
torino335 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torino335 Quote  Post ReplyReply Direct Link To This Post Posted: 17-March-2017 at 1:46PM
i have a few,got a picture?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2017 at 3:43AM
I know thats why I asked. I have no idea. I have the c4 out of a 77 400.Traded the aod for a rebuilt ? 400 2yrs ago. though I would go with the c4 have a 164 or63 tooth flex plate .my motor is a 74 falcon.This is the one thing I never liked about ford. Why so many choices.
Post Options Post Options   Thanks (0) Thanks(0)   Quote torino335 Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2017 at 7:35AM
i have a 77 302 bell housing out of a 77 granada,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2017 at 5:04PM
the bell has to match the car as much as the engine/trans, little things like the bosses to mount the bracket for the column shift cable are a big deal if you need them and they're not there
and a 6 cylinder bell will mount the starter in a bad place for a V-8 Disapprove
small flex is 157 tooth, large flex is 164 tooth
i forget which but one bell mounts using the pump bolts and the other has it's own bolts around the outside of the pump, and IIRC the small flex trans has the dip tube going into the top of the case (case fill) and the large flex has the dip tube going into the side of the pan (pan fill)
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-March-2017 at 5:23PM
not sure but i'm guessing bob is wanting this for his pinto, so they are all floor shiftered
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 19-March-2017 at 2:04AM
Right. the one for mustang 2 is the small flex plate. My trans is a pan dip stick which could cause problems. Starter location and bolt pattern also come into play Here is were I don't care for fords.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 19-March-2017 at 3:18AM
Pinto / M-II is a completely different animal, way smaller than 157 tooth
135? i thought it was 14x something but it's small and the bell needs to match the tooth count or the starter will never touch the ring gear
ilyes had one in his old Torino maybe he can shed some light, or pull up his old project thread. aftermarket may be the way to go on this one, i believe I've heard of hybrid bells that attach to the pump bolts on pan fill cases. will a 157 tooth bell even fit in the stock tunnel?
Edited by Rockatansky - 19-March-2017 at 3:24AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 19-March-2017 at 3:43AM
You are correct. It had a 302 with AOD. I did not think when I gave away the trans for a 400 motor I would have so many questions going to a c4. I do have a 89 300 van w AOD but it seems only up to 87 will fit a 302. Should have left well enough alone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote torino335 Quote  Post ReplyReply Direct Link To This Post Posted: 19-March-2017 at 6:36AM
you said you have a 74 302,was it column shift ?,your trany is 77 c4,pretty much all will bolt up,i had every granada from 75-78 including 78 cougar,72/73 351 all the engines 351c.351w 302 all fit in a 75 granada i had,never had to change anything,i even put a 69 351w in a 76 granada,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 19-March-2017 at 9:49AM
you wouldn't want to put a 6 cyl AOD behind a V-8, smaller clutch packs they don't hold up long term
back to basics, what year 302 in what year / what car?
engine year (specifically the crank shaft) determines flex plate balance weight, 50 vs 28 oz
Edited by Rockatansky - 19-March-2017 at 9:50AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 19-March-2017 at 10:18AM
if you have a pan-fill, best answer is get another transmission. As far as I remember, those are all the large flywheel and use a different bell than case-fill.
Pan-fills are bulkier and have odd parts sticking out in stupid places.
A small bell case-fill will fit in a pinto with some love from a sledgehammer. There is a raised seam at firewall-to-trans tunnel that will need to be flattened, and some small contact areas will need love as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-March-2017 at 10:38AM
yep, may need to use a BFH!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 19-March-2017 at 11:10AM
The motor is a 74 car is a pinto floor shift. I had a AOD in it so the fire wall was worked over.
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 19-March-2017 at 12:54PM
My first torino had an original c4 with a 302 that came stock. If I recall, it had a 157 tooth flexplate
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 19-March-2017 at 1:09PM
For V8s, 157 is the "small" flywheel, 164 is "large"
Mustang II was smaller than "small".
