  New Posts New Posts RSS Feed - Big block motor mounts
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Topic: Big block motor mounts
    Posted: 13-February-2021 at 7:06AM
Mounts for a 76 Torino or any interchangeable car. Going from a small block to 460. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2021 at 8:38AM
a guy i know swapped in a 460 from a lincoln with those mounts idk he said something was a little different?? but the shop he had so it made them work, what exactly they did idk...
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2021 at 9:21AM
thanks Johnny. Ya I heard I can’t use truck mounts. Lots of differences. Hope to find a interchangeable car like a montego, cougar or tbird
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2021 at 12:36PM
idk what the minor difference was but the mid 70's lincolns use most of the same suspension parts as torinos so i'd think the cross members should be the same? yeah trucks use a tower style...
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2021 at 12:48PM
ya? Guess maybe they’d work too. Sure like to find out
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 14-February-2021 at 12:49AM
For the engine swap to be a "bolt-in" type of deal, you will want engine mounts from an intermediate, like a Gran Torino, Montego, Cougar, '75-'76 Thunderbird, Ranchero and Lincoln Mark series(full-size-Continentals and Town Cars use different mounts as do the Mercury Grand Marquis). With that said, I have never tried to make the full size mounts work, just remember, that headers(if you want to have the option to use them) are based on fitting with the factory "correct" engine mounts. Header fit is usually a PITA even with the correct mounts-just sayin' . Hope this helps
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Posted: 14-February-2021 at 1:38AM
more than helps!! Great info! Now trying to find some is gonna be a chore! Thanks!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 14-February-2021 at 12:30PM
Crites makes swap mounts. Thiers appear to be nothing more than fullsize mounts modified with a bracket to straddle the torino/intermediate crossmember. They do not position the engine in the factory location and require their matching headers.
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Posted: 14-February-2021 at 12:36PM
ok I’ll look into that now. Thank you
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2021 at 10:35PM
I’ve got a pair of insulators if you’re interested. OEM Ford.
Jeff
76 Mercury Montego MX Villager w/ 460 (SOLD)
79 Ford Thunderbird w/ T-tops
69 Ford Country Squire
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2021 at 10:37PM
There’s a complete set on eBay. Includes frame mounts, insulators, and heat shields. I think they’re priced at $350
Jeff
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2021 at 5:35AM
so this isn’t complete? I think there’s 3 parts to a complete set? Thanks
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2021 at 5:37AM
I’m not sure if the one on eBay will work on my Torino? That’s my concern. What’s the title or # on eBay, maybe I haven’t seen it yet? Thanks for the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2021 at 12:10PM
All I had was the insulators. They already sold. The eBay set is correct and complete.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2021 at 1:23PM
Ebay set is a mixed set. the one engine plate is the pre-73 version, the other is 73-up.
Doesn't affect fit, just fun to see.
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2021 at 2:51PM
so eBay is a complete set? Sorry I’ve just started looking. All I know is it has to be mid sized
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2021 at 2:54PM
I just looked. Think I’ll buy if he ships to Canada. Really appreciate it thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 23-February-2021 at 12:09PM
72-76 t birds with 429/460 motor mounts are a direct fit for the ranchero/torino/montego 72-76 and for engine swapping in a 77-79 cougar/LTD II/ ranchero.
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Posted: 23-February-2021 at 12:47PM
thanks Dan!!
This page was generated in 0.046 seconds.
