  New Posts New Posts RSS Feed - Block #
Block #
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Topic: Block #
    Posted: 26-May-2017 at 8:06AM
I know it's a Cleveland, but on the back of the block behind the driver's side head, the # on the block is 3A202817. What does this number mean? Thanks
Matt
1969 Mercury Marauder 390
1972 Montego MX
2003 Mercury Marauder 300A
1994 F-150 5.8
2016 Ford Fusion Titanium
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2017 at 9:09AM
sounds like you found a partial VIN, some blocks got stamped to the original vehicle / many didn't
if it is a partial VIN,
3=1973
A=Atlanta assy plant
if the first 2 is really a 3 it comes back to a Torino body and the remaining 02817 is the line sequence #?
otherwise i can't find any 2 or 20 body code
Edited by Rockatansky - 26-May-2017 at 9:18AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2017 at 9:25AM
Yeah I looked it up like a normal VIN, but got stumped at the "20", also. Doesn't conform to any Ford body style I can find.
The whole engine is kind of a mystery. It has 400 heads on it, according to the numbers stamped on them (D5AE-A2A) but came out of a 73 GTS I parted. I assume the engine was replaced with something else over the years, but why put the 400 heads on? Has Cleveland exhaust manifolds by the #, and it was a 2V intake.
Matt
1972 Montego MX
1994 F-150 5.8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2017 at 11:14AM
"why put the 400 heads on?"
Because
1. They were available.
2. Pretty much the same as open-chamber 2V heads.
3. They fit and work fine.
They might also be off a 351M as they used the same heads as 400 in any given year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2017 at 1:12PM
the D5 casting code dates them as production model year 1975, those are the heads with the water jacket invading the exhaust port and they may have A.I.R passages plugged in the rear? surprisingly if the rest of the combo supports it they're capable of making over 400 maybe 425 hp
anything D5 i just call them 351M heads because that was the first year for the 351M
but yup like BB says it's pretty common to find them on a 351C-2V
and on that note, be careful adding any kind of aftermarket or even stock 351C cam to those heads w/o having them checked / re-worked for additional lift. Bubba's page documents a warning about anything near or over .480 lift
Edited by Rockatansky - 26-May-2017 at 1:15PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 28-May-2017 at 12:13AM
Still don't know what I'm going to do with this engine sitting on my garage floor, but thanks for the info. I'll pull the heads off soon to take a closer look at the guts, and maybe that will help me decide whether to keep it for a possible rebuild, or just get rid (sell) of it.
Matt
1972 Montego MX
1994 F-150 5.8
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 28-May-2017 at 12:41AM
If its got 400 heads on it it'll be a turd.....low compression and horrible....would just sell it off unless you want to find some cheap closed chamber heads and rebuild it to flip
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 28-May-2017 at 2:37AM
a couple or more recent builds have lifted my opinion of the turd heads somewhat, they'll make 400 / 425hp with the right combo, not bad for junkyard boat anchor doorstops?
with your 72 & 73 can't you use a back up short or long block for a time when you think you'd like to fresh one of those?
or just use it as a complete swappy after a proper do-over?
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 28-May-2017 at 3:00AM
Actually that's kinda the way I'm leaning. I know the heads in my 72 are correct, so simple rebuild on the spare block, swap heads and off I go. Maybe recoup some of the $ by selling the 75 heads.
Matt
1972 Montego MX
1994 F-150 5.8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 28-May-2017 at 5:18AM
I'm even thinking of a Cleveland swap into my 2003 CVPI, make it run off all the original fuel & electronics, emissions compliant & tune through an SCT handheld. not sure what to do about the E-auto trans though, i'd probably go to a C6 if it'd fit under the car rather than an adapter, maybe a Mustang manual trans ECM?
