  New Posts New Posts RSS Feed - ...body buck tags on 72 GTS
picon3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote picon3 Quote  Post ReplyReply Direct Link To This Post Topic: ...body buck tags on 72 GTS
    Posted: 05-April-2013 at 3:48AM
Received an email this morning from someone asking about body buck tags on 72 GTS.  I think that what we figured out the last time this issue came up was that some cars had them and some didn't.  What's the latest on this issue?  Thanks, Paul~
1972 GTS 351CJ-4V black/black
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 05-April-2013 at 8:05AM
After doing a quick google search, it seems that Atlanta cars didn't have them? I'm pretty sure mine does not and it was an early Atlanta build.
1994 Mark VIII
Retired 60s NHRA Anglia
iangj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iangj Quote  Post ReplyReply Direct Link To This Post Posted: 05-April-2013 at 9:46AM
There are 2 of them and they are hidden under the dash right up by the windshield and they are part of the body/firewall. They don't have all the info like the older cars used but just a partial VIN #
You can see them in this picture by the defroster ducting.
Edited by iangj - 05-April-2013 at 9:49AM
Ian Glyn-Jones
Fonthill, Ontario, Canada
Montego GT Registry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 05-April-2013 at 10:17AM
both of my rancheros have them and they are 74 and 79. They have the complete Vin # on them. also have a partial Vin# stamped on both sides under the carpet above the rockers.
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 05-April-2013 at 11:04AM
my oakville built 72 sport had them.  they were screwed to the firewall below wiper motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 05-April-2013 at 3:47PM
429SPORT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 429SPORT Quote  Post ReplyReply Direct Link To This Post Posted: 24-April-2013 at 10:17AM
MY '72 OAKVILLE ONT. BUILT GTS DOES HAVE ONE. AS WELL AS BODY COLOR FIREWALL.
MIKE
1968 PONTIAC GRANDE PARISIENNE 427
1972 FORD GRAN TORINO SPORT 429
kversch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kversch Quote  Post ReplyReply Direct Link To This Post Posted: 27-April-2013 at 7:48AM
three of the 72's we have had the same tages Mike posted about.    If I recall it the three cars I have were Canada built cars.
-kevin-
Brown 72 gran torino 351c 2v
Black 73 GTS FB 302
Red 73 GTS FB 351C C6 trans
73 GTS FB Parted
97 F250 crew cab 7.3 diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 27-April-2013 at 8:34AM
Ian,
On my '76, those two tabs in front of the defroster vents have the consecutive assembly number of my car stamped into them as you said. My current car didn't have a body buck tag or it was removed. On my '76 S&H LE, the buck tag was on the upper surface of the firewall over by the passenger side hood hinge.
I THINK you car order the buck tags from Marti..... not sure if it's ALL models or certain ones. When I get a bit closer to having mine done, I'll look into getting a new one a bit deeper.
rudy52397 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudy52397 Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2015 at 5:08PM
Did the 73's built at Lorain have these? I haven't been able to find one
-Rudy
1973 Gran Torino, 2 door hardtop, 302, original Ivy glow paint
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2015 at 6:26PM
FWIW my 74 was built in oakville and it had the tag by the wiper motor and the vin stamped on the tag by the defroster duct, but i never seen any vin #'s stamped by the rockers???
also, i never seen any vin #'s stamped on the frame anywhere, did the torino's have any on the frame?
Edited by californiajohnny - 12-September-2015 at 6:29PM
Billy C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy C Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2015 at 12:37PM
I have a 72 GTS. I've honestly never seen any anywhere except on the dash and I have had the car completely apart except drilling spot welds. The sticker on the door jam was long gone. I didn't look under the front windshield when I had that changed so some could be there. Lot's of date stamps on the frame but no vins.
-Billy Conturo
SEKCOBRA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2015 at 3:28PM
Has anyone else seen this tag on the drivers side frame rail by the gas tank???
69 MACH R CODE
70 TORINO COBRA J CODE
71 TORINO COBRA J CODE
72 Z28 CAMARO
94 MUSTANG 5.0 LX NOTCH
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406 tri power
64 galaxie country sedan 390 3 spd/OD
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2015 at 12:33AM
My car has numbers like that on the frame in the same spot. However they are stamped into the frame, there is no tag like yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2015 at 1:57AM
I thought there may have been numbers stamped under there and possibly some mistake so they welded this plate over them.
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2015 at 4:01AM
Every Torino/Ranchero I've scrapped had the tags under the windshield. Only a couple had the removable tags. I have never found any other numbers on any other body parts but will take a look at the 3 frames I have sitting. The only exception was Stripper's 250 engine had the complete vin number of my car on an engine boss. I posted a picture of it on my thread.
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2015 at 4:57AM
I can't find any tags anywhere on mine, and wouldn't know where to look for a tag/stamped numbers on the frame on a wagon. Built in Atlanta in November 1972.
Edited by GTW - 17-September-2015 at 4:58AM
1994 Mark VIII
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2015 at 5:20AM
You MAY find a VIN, or a partial VIN, under the carpet on the floor in the area between the seat and the rocker, where the frame is channeled under the floor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2015 at 2:01PM
I forgot to mention, my Oakville built cars had the tag near the firewall and the two tabs by the defroster ducts with partial VINs.
Edited by 72FordGTS - 17-September-2015 at 2:01PM
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2015 at 2:12PM
