Body mounts and core support bushings. |
Anderslober
Senior Member Joined: 30-July-2019 Location: Denmark Status: Offline Points: 763 |
Posted: 23-August-2019 at 11:41PM |
Hi again forum. I have been reading through a lot of the info on this forum about bushings.
Can it really be true, that there is no bushing `kit` for our 72 GTS`s? We have to use Chevelle bushings?. No other Ford bushings fit?? Tahnks....
1973gts
Senior Member Joined: 05-March-2018 Location: Grand Rapids Mi Status: Offline Points: 608 |
In the 72-76 section there is a post with a very good discussion on body mount bushings, most are using the crown vic sets, they seem to be the closest to original.
Dave - 1973 GTS N code
Anderslober
What year for the crown vic bushings?
We need to put pressure on Energy Suspension to make a set!!
1973gts
INFO: 1972-1979 Body Insulator Bushings - UPDATEDCheck out page 4 of this post in the 72-76 section of the forum, should be the info you need.
Dave is correct, read that thread there is tons of info. Here is the direct link:
Spend some time and look at the stickies, the technical articles section and the how to section. There is a ton of information all over this forum.
Anderslober
I have read all the excellent info.
Please check Ebay item number 361931123054. Will this crown vic kit do the job? Thanks...
order from Rockauto and save, depending on shipping |
Anderslober
ok..Rockauto....gotcha.....but, is it the correct set/kit?
those are the bushings mentioned all throughout the thread as far as i can tell, yes
