Body side molding clip style and placement. |
Gold73
Member Joined: 02-July-2018 Location: Kansas Status: Offline Points: 90 |
Posted: 08-August-2018 at 2:00PM |
Does anyone have photos of a 73 GTS with the lower door,fender and quarter panel wide trim removed for painting? If so are all trim pieces attached with the center stud metal type mounting clips? The reason I ask is I bought a rust free replacement door and it has two rows of small pins mounted to the door skin for small plastic clips to mount too and holes in the front and rear edge of door for center stud type mounting clips. If so how do you install pins for plastic clips. Wow what a mouth full of questions! Any help would be greatly appreciated.
i know the fenders have 4 holes for the bolt on clips, i believe the doors have holes at the ends and welded on nail head looking studs for the plastic clips in the center of the door? Malcolm would know! he has that style molding on his car i believe they could be spot welded on with like one of those stud gun dent puller things??? IDK but i'll need to weld on a bunch of those nail head thing when i get to that point on my mustang as the new metal doesn't have them for the front or rear window trim
the 74-76 cars that have the low rocker trim have pop rivets that hold the plastic clips on... that's an option but if they had the nail heads i'd try to have them welded back on |
