bolt pattern |
HPM711
New Member Joined: 08-November-2013 Location: PA/NY Status: Offline Points: 3 |
Posted: 02-December-2013 at 2:23PM |
i have a 73 Gran Torino with an 8 inch rear end. I'm trying to get new rims but im not sure the bolt pattern i need. I've looked online and got mixed results between 4.50 and 4.75
5 bolts on 4.50 circle.
n2fordwagons
Yup, 5x4.5. Don't know of any Ford that would have 5x4.75. As far as I know, that's a Chevy bolt pattern.
Jeff
unlovedford
Ford small - 5 X 4.5 (5 X 114.3) Same as lots of imports.
Ford large - 5 X 5.5 (5 X 139.7) GM small - 5 X 4.75 (5 X 121) GM large - 5 X 5 (5 X 127) These are the bolt patterns used for years until recently. Now other patterns have been added additionally. |
Ford fullsize 1973-1978 would be 5x5
Inkara1
Senior Member Joined: 17-November-2021 Location: Ridgecrest, CA Status: Offline Points: 282 |
I know this is an old thread, but for those searching for answers later, my '72 Gran Torino wagon has a 5x4.25 bolt pattern. I bought 5x4.5 bolt pattern wheels and they didn't go on.
5x4.25 is apparently also a common Mopar pattern.
aquartlow
Ford intermediates of the 70's have 5 on 4.5" bolt pattern, the full-size cars(Lincoln Continental-the Big T-birds-Mercury Marquis) have 5 on 5" bolt pattern. A 5 on 4.25" bolt pattern were on later model Fords/Lincolns-I believe a Lincoln Mark VIII had the 5 on 4.25"bolt pattern. Unless someone has done something funky to your '72, it should be 5 on 4.5"
shanewherry
Member Joined: 27-March-2021 Location: Alberta Canada Status: Offline Points: 66 |
So are the wheels lug centric or hub sentric? What soze hub do I need if I want to use Mustang or Crown Vic wheels?
1973 Gran Torino Wagon
400/C6 |
1972 Torinos were 5 x 4.5" (same as Mopar) like Todd says. Torion Police cars were 5 x 5" for 1973 and newer.
Wheels were generally hub centric except for Magnum 500's which are lug centric. I am not sure the hub size off the top of my head, but I know several members have used late model Ford wheels. Check the Centric website and look up the rotors. It will show the specs on the hub bore size.
shanewherry
Thanks.
77.8mm bore
400/C6 |
Inkara1
So did I measure incorrectly? I went from hole center to hole center across the pattern (in the same way one torques down 5-lug wheels) and got 4.25. I just put new front rotors on, listed as fitting a 1972 Gran Torino, and the wheels fit.
I bought Ford steel wheels from the junkyard. I measured before I put the tires on, and one measured 5 inches at the hole centers, so I swapped it at the junkyard. But those are the ones that didn't fit. So I had the tires remounted on the non-Ford steel wheels that came with the car (except I had to find another Mopar steel wheel because mine had three 15-inch Mopar wheels and one 14-inch Ford wheel when I got it).
aquartlow
This should help:
you have to add a smidge when measuring a 5 lug, cheating from the outside of one stud to the center factors in the smudge
Also, 60s Ford 5x4.5 had a smaller hub bore, and those wheels won't fit newer cars with the 78mm hubs.
