  New Posts New Posts RSS Feed - Boxing rear control arms
SininenIII View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SininenIII Quote  Post ReplyReply Direct Link To This Post Posted: 09-March-2014 at 5:24PM
Super nice work!
Aatu
73 Gran Torino Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 07-February-2015 at 12:52PM
In the process of boxing my LCS's. I have the inner braces welded in and today I tacked the bottom plates into position. I'm trying to decide if I want to cap off the ends and weld it completely closed, cut the end caps a bit short to allow for an opening at each end of the flat section or leave the entire ends open. I'm leaning towards leaving an opening at each end of the flat section to allow water to esape and air flow to keep things dry inside.
Suggestions??
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 07-February-2015 at 1:20PM
joe, i left mine open on the ends (because i cheated and used angle iron from a bed frame to fill in the bottom with the extra angle part inside for extra support Big smile)
