Brake Lights Not Working - Help |
havanariviera
Senior Member Joined: 24-August-2015 Location: Pennsylvania Status: Offline Points: 243 |
Posted: 28-August-2016 at 4:39PM |
Hi
group - I've been searching on this topic for a couple hours, and am not sure
which direction to go. I just noticed that my brake lights (72 GTS) aren't
working, although they did work when I last checked a few months back.
My 'reverse lights' work, both 'turn signals' work, and the 'tail lights'
and 'side lights' also still work (when the headlights are turned on).
A few questions:
1) are the 'turn signal' and 'brake' bulbs the same?
2) are the 'tail light' and 'brake' bulbs the same?
3) are the terms, "brake lights" and "stop lights" synonymous? (I'm asking
because I see "stoplights" indicated as position 7 on the attached
diagram) From reading a few threads, I was able to
glean the following: it appears that the
brake pedal activates the brake lights via a signal coming from the "brake light
switch".
I'm a real novice, so anything too complex and I'll have to have it worked
on professionally. I'm hoping that maybe there is a fuse that might be causing
it??? - and it's something I can resolve myself. If
this is the case, does anyone have a picture of what the "brake light switch"
should look like?
And,
does anyone have a picture of the fuse box? (and confirm which fuse I would need
to replace)
Please
see the diagram and let me know if I'm even in the right ballpark of what to be
looking at here. Any guidance or suggestions would be much appreciated. Thanks
in advance! |
there should be one labeled stop on the fuse box
yes brake and stop are the same the turn signal element is the same as the brake light in the bulbs check all the fuses first if they are all good and making contact on both ends of the fuse then check for power at the brake light switch (one wire will be hot the other should have power coming out as the switch is activated which runs up into the turn signal switch and onto the rear bulbs the brake light switch is on the brake pedal up near the steering column, looks like this: |
Definitely check the brake light switch. The one on my car has been replaced a couple times in it's life for failing.
COTorino
New Member Joined: 25-September-2018 Location: Arvada, CO Status: Offline Points: 19 |
The turn signals on my '72 are not working. I only have ONE fuse - top right "hazard flasher'... do I need the second or is the diagram just a variation for multiple model years? ...Hopefully it is that simple...but I somehow doubt it... Pic below:
'73 Torino H Code Sport Top
Wife named her "Baby" |
7T9_Tbird
I went through this on My 'bird. Yes, you need both flashers in place for the system to function.
John
COTorino
THANKS T BIRD!!! Parts store had two new flasher fuses. Front and rear signals are working!! Now just have to get the side ones going.
7T9_Tbird
No Problem. Here to help!
John
2beginers&70Trorino
Brand New Member Joined: 31-July-2021 Location: 80516 Status: Offline Points: 1 |
got a 79 Torino Hardtop, two door, straight numbers, I did turn the original 302 into 347 stroker..
Rear break and signal will not work. The front and side signals work. Running lights work when on. Really perplexed here! Any help would be appreciated!
